Please help,
This is my dilemma:
Item: Older powermatic 1.5hp motor on a 64b
Problem: Motor bogs down quickly.
Solutions implemented to date:
1. New motor and arbor bearings
2. No open or short circuits in windings
3. New belt adjusted and new blade
4. All spins smooth by hand
Amps drawn during labor
8amps on one leg
8amps on other leg (wired for 240
It rarely bogged down in past and now it slows down as much as I do.
Any solutions I've missed???
Have you measured the incoming voltage? I ask because the symptoms exactly describe how a 240V motor would behave when running on 120V. What is it drawing on no load? Run the saw for a few minutes and then feel around all the bearings for elevated temps.
Bogs down doing what?  How big of a cut?  Blade and fence aligned nicely?  Tension in board?  Jointed edge first?
The operator can easily win a fight with a 1-1/2hp table saw.
You stated new motor so I .will assume it has to be external to the motor. You state it sins freely by hand. I’m going to go with your only feeding it 120 volts. You may get an erroneous reading with your current meter. If you measure a rod you line in and get ~240 then maybe your motor, which can be wired for 120 or 240, was set up for 120 out of the box, but if you had this problem before the new motor, could really be your line In voltage.
  • Who's Online   3 Members, 0 Anonymous, 41 Guests (See full list)
    32k
    437.5k
    Bob44
    Bob44
