Dankma Posted July 16, 2023 Report Share Posted July 16, 2023 Hello! I make guitars. I'm planning to use a Nitro Lacquer-based color for the base coat, and then I'm planning to clear coat it with either automotive urethane or polyester clear. I don't wish to use Nitro Clear for the top coat. I was wondering if I would have any adhesion or compatibility issues using those materials? Thanks in advance! 2 Quote Link to comment Share on other sites More sharing options...
wtnhighlander Posted July 17, 2023 Report Share Posted July 17, 2023 Welcome, @Dankma! I can't speak from experience with that particular combination of finishes, but the only adhesion problems I HAVE experienced involved laying polyurathane over a simple drying oil, like linseed. As long as you allow the base coat to fully cure, and follow the mfg. directions for top coat application, I suspect you will be successful. 2 Quote Link to comment Share on other sites More sharing options...
Mark J Posted July 17, 2023 Report Share Posted July 17, 2023 Customer service for the products in question might have some insight. A test panel might also be worthwhile time spent, though that won't give you long term performance. I'm just curious, why not a top coat of clear lacquer? Quote Link to comment Share on other sites More sharing options...
Dankma Posted July 18, 2023 Author Report Share Posted July 18, 2023 On 7/17/2023 at 8:23 AM, Mark J said: On 7/17/2023 at 8:23 AM, Mark J said: I'm just curious, why not a top coat of clear lacquer? Thanks for your answer. I honestly don't like Lacquer at all, too much work for what i consider a finish with poor protective qualities, altough it polishes really nice Quote Link to comment Share on other sites More sharing options...
