Ron Swanson Jr. Posted February 11 Report Posted February 11 As long as you havnt glued it you should be able to pound it out by tapping the inside face of the tail board to separate it from the pin board. Even if it's tight it should separate. 1 Quote
wtnhighlander Posted February 11 Report Posted February 11 If you can combine a spreader (constant force) with light taps with a moderately heavy hammer or mallet, you'll have an excellent chance of separating it without damage. Either method alone should work, but combining them reduces the shock load on the joint. 2 Quote
Popular Post Mark J Posted February 12 Popular Post Report Posted February 12 If the above ideas don't work, try this. Lay the tail board (light colored piece) on a workbench with the pin board (darker) hanging down. Clamp the tail board in place. Now using an appropriately sized dowel tap out the pins from the tails. Once you get the joint separated, consider if you need to make it slightly looser, given that the wood fibers are going to swell when you put glue on them. 3 Quote
Sergio Escudero Posted June 11 Author Report Posted June 11 I'm not really sure how to proceed. On one hand, I'm concerned about the fact that once everything related to the wagon and the screw is glued, there will be no possibility of disassembly because the width of the planks is less than the width of the nut base that is set into the endcap. To be able to disassemble it, I would have needed to use 70mm planks, which I didn't have and was excessive. Right now everything works very smoothly and the wagon has really minimal play (just enough for wood expansion with humidity changes), but I always have the fear that something might happen and it won't be fixable. Probably unfounded fears, since I shouldn't ever have to do anything to it. The thing is, I'm at a point where either I can glue almost everything already or not. The endcapis fitted with a tenon and mortise, and the two planks that fix it go with dovetails. The lower plank is still in process, and I wonder whether I should finish it and glue everything at once (the two dovetailed planks and the endcap) or only the plank with the finished dovetail and the encap, and once dry, finish the recessed dovetail and glue that last plank. I think that with this last method, the chances of something shifting during gluing might be slightly lower, but I'm also worried about the endcap because I have no way to apply pressure in the right direction during gluing. By the way, should the tenon and mortise fit tightly or be left unglued? Should I remove a couple of millimeters from the length of the tenon in case the wood moves? Right now it fits like a glove. By the way, should I finish the inside part with the grooves where the wagon slides before gluing? I think I'll go with something like Danish oil, partly penetrating and partly film finish. Since it's a film finish and the wagon is in the middle, I won't have an easy time applying the finish to that part. Although the wagon slides well, as I said, I also plan to apply wax. 2 Quote
Popular Post Ron Swanson Jr. Posted June 11 Popular Post Report Posted June 11 Maybe I'm off base here, but could you cut a notch on the 2 pieces that butt up to the plate to allow access to the screws and room for the plate to be removed? As to your finish question, a little paste wax wouldn't hurt but i don't see much need for finish in there 3 Quote
Sergio Escudero Posted June 11 Author Report Posted June 11 The problem is that behind the base there is an almost tubular part of 42mm long, so I need a recess of at least 54mm, which is exactly what the nut measures in total. If I do that, I remove 54mm of the wagon's travel, which can also partially come out of the groove, and I'm sure it will cause problems. As I said, everything works fine now and should stay that way during gluing. My question is: Has anyone needed to disassemble or perform maintenance on their vise within the first 10 years? Quote
Ron Swanson Jr. Posted June 11 Report Posted June 11 No to the disassembly, though I'm on year 3 of a similar vice Quote
