Light to medium raps with a mallet are fine, but if you have to beat it into submission, you're too tight. Also, if you're seeing bruised fibers in either the M or the T, you know exactly where you're too tight.
The best comparison I've heard for the ideal fit is like a cork in a bottle.
Keep up the good work. You're doing great.
  • 3 weeks later...
  • 3 months later...
17 hours ago, Sergio Escudero said:
with less than 0.1 mm tolerance,
so I think the problem must be that the new groove is slightly out of alignment and not parallel
The two grooves may not be parallel, or maybe one or both are not deep enough.
But I'm wondering if the tolerance may be too small.  0.1 mm is about .004 inches.  That may be too tight for something made of wood, rather than steel.  Just a thought.
You mentioned that the vice block guides are glued up, so I gather it's not possible to disassemble and test the components separately.
On 2/11/2026 at 11:57 AM, Sergio Escudero said:
But now for the problem. I have to separate both pieces to insert the screw into the wagon. The joint is very tight. I'm going to have a hard time separating it without breaking it, and I don't know how I'm going to do it.
Yikes. Very gently? I'd try tapping it with a hammer and see if it can be persuaded. I would also keep the joint as dry as possible to reduce any swelling. Easier said that done I know.
I'm just guessing, but maybe use a heat gun to dry out the wood as much as possible?  Also, heat softens pitch and stuff.
Maybe instead of a hammer, use a spreader (bar clamp reversed) to apply very gentle persistent pressure.
Again, just guessing.
  • Who's Online   2 Members, 0 Anonymous, 79 Guests (See full list)
    32k
    437.5k
    26,007
    FurniCore
    FurniCore
