White cast after sanding on oil based spar urethane
We have two wood door that we got from home depot. They were raw wood. So we stained twice and then used oil based spar urethane to seal (with appropriate dry time between coats). we did the first coat waited 5 hours did the next coat waited like 6 or 7 hours and then did a third coat. After that we waited for 6-7 hours then put the doors away to finish for another day. When we came back to them we sanded them lightly with fine grit, used a wax rag and a lightly damp rag to get dust off. I looked at and it looked like it had a white cast on it. i tried to wipe it off still but nothing worked. I'm not sure what to do from here.
Maybe the product you used lists a shorter cure time on the label, but most urathane in my experience needs 24 hours between coats. Also, how fine is 'fine grit'? Sanding the finish usually means 320 or greater.
Last, you say this is Spar urathane. This type product is designed for boats, where wood movement is a given. To accommodate the movement, spar finished are formulated to remain softer, more pliable than typical furniture finishes. As such, Spar urathane will likely not polish to the high gloss achievable with a hard furnitute finish. You might need to apply anothet, thinned coat to restore the luster.
We chose the spar urethane because we have a cat that pees on doors. So we thought the most water resistant finish would be best. We didn’t realize that it was mean to be a softer finish. Sanding was done with 440 grit, but to fix this what would be the best recommendation? Keep sanding with even finer grit? Or just put another thinner coat of finish on?
First, welcome to the forum. Like Ross said, it could be due to layers not curing enough before the next was applied. You might try putting a thin layer in a small inconspicuous spot to see if the haziness goes away. If not, you'll probably need to sand through the layers and start over again to get the look you're going for. Either way, let us know how it goes.
I know a little something about spar varnish (see avatar).  The last coat is not meant to be sanded.  That "white cast" is simply scratches in the finish, and that's OK.  Give it a little more dry time, then add a full strength coat.  Don't sand that final coat.  It should fill the previous sanding scratches, and stay "glossy" (assuming it's a gloss finish).
