imAsta Posted July 25 Report Posted July 25 I'm laying out joinery on a large cabinet side, and I'm finding it surprisingly easy to lose track of the reference face once the panel has been flipped around a few times. The piece is too big to leave in one position on my bench, so I have to rotate it every so often, and that's where I start wondering if I'm still measuring from the correct edge. I already marked my reference face and edge with pencil, but after moving the panel around several times, those marks don't seem as obvious as they did at the beginning. I'm worried that one wrong measurement or marking from the opposite edge could throw off the mortises enough to cause problems during assembly. Do you have a simple way to keep everything organized on larger panels? Do you make bigger reference marks, use cabinetmaker's triangles, blue tape, chalk, or something else that makes it almost impossible to confuse the orientation? I also use an online compass once in a while when I'm moving long boards between different places. An online compass is a browser-based digital navigator that uses your device's GPS location and built-in compass sensors to show direction. It's obviously not a precision woodworking tool, but I've found it useful for quickly checking orientation when I'm away from the bench and trying to remember how I had a board positioned before bringing it back inside. Another thing I'm unsure about is when you actually cut the joints. Do you finish marking every mortise and tenon first, then start cutting, or do you mark and cut one section at a time so there's less chance of mixing up reference faces? I'd love to hear what works for people who build larger cabinets or bookcases. Have you found a marking system that has saved you from making one of those frustrating "everything was measured from the wrong side" mistakes? I feel like this is one of those problems that only shows up once the parts get too big to handle comfortably, and I'm interested in seeing how other people deal with it. 1 Quote
wtnhighlander Posted July 25 Report Posted July 25 All of the layout techniques you mentioned are useful at various stages of construction. I suggest you select a marking method that is easily visible, such as chalk or brightly colored tape, and use that for your reference marks. Use something else for the joinery layout, so the markes don't get confused. 2 Quote
Von Posted July 25 Report Posted July 25 I've learned to use blue tape and label things copiously. Nothing is ever as obvious when I come back into the shop the next day (or next week as the case may be). What I like about blue tape is if I need to, I can take it off temporarily if it's in the way (e.g. to sand) and then put it back on. 2 Quote
Popular Post gee-dub Posted July 26 Popular Post Report Posted July 26 I potentially mark parts way over the top. I generally use chalk since it gets removed almost completely through normal surface preparation. If flat surfaces will be milled or sanded away I mark the edges or ends. It is way easier to remove marks than to remake parts if I mess up. 3 Quote
