pkinneb Posted October 20 Report Posted October 20 All my shop is about 20ish years old and I have started having issues with my Phillips F96T12/C50 bulbs/ ballast. Well unbeknownst to me one can no longer easily purchase replacement florescent bulbs so I have started looking for LED replacements and have some questions for anyone who has done this: 1. Is type A or type B (ballast bypass) better than the other? 2. Are the color outputs similar? E.G. I have 5000K daylight bulbs now will an LED 5000K be similar? 3. Will I notice if I don't swap all 16 fixtures at the same time? 4. Other considerations?? Not sure it matters but I have 10 - 8' dual bulb (single pin) fixtures and 6 - 4' dual bulb (single pin) fixtures. I wired the original shop so other than access over the equipment not to concerned about rewiring to bypass the ballasts. Thanks in advance for any insights! Quote
Tom King Posted October 20 Report Posted October 20 Get the kind that doesn't need a ballast. Simpler to just take the ballast out and get rid of it. Get new tombstones that fit the T8 tubes. They snap right in. Keep the wire off the old ballasts. You will probably need some. If you find strippers that will easily strip the little high temperature wires, please post to let us know. I bought some Japanese ones after already buying every kind I could find that none worked like I would like them to, but haven't tried these new ones yet. Stripping those wires is the worst part of the job. The ones I've replaced were not 8 footers, so let us know what you learn in that part of the process. I used Wago connectors instead of wirenuts. Color temp should be close, but the new ones will be a lot brighter than the old ones. I would do them all while you're into it. I hope you have a platform ladder the right height. Might need to cobble up a little stage to work the whole 8' length at the time. 1 Quote
drzaius Posted October 20 Report Posted October 20 I agree with Tom, use the ballast bypass type. You will notice a slight difference between the 50K LED and fluorescent lamps, just as there is between different manufacturers of fluorescent lamps. No enough to be significant though. Color rendering (CRI) is something else to pay attention to. Once you get below about 85 there can be weird color cast to stains and paint. 1 1 Quote
pkinneb Posted October 21 Author Report Posted October 21 Thanks guys!! This was really helpful. Quote
