aschaeffer Posted January 8, 2012 Report Posted January 8, 2012 I am fairly new to woodworking and have only built very simple projects. I am attempting to build a radiator cover and am having an issue making straight cuts. I do not have a lot of room and have limited tools so I bought a jigsaw that I think I can make all of the cuts for this project with. I am very frustrated now because I cannot make simple straight cuts. I am using a straight edge to guide the jig saw however after making about 6" of a cut I notice the blade on that saw starting to push right (towards the guide). After 10" I am a full 1/8" closer to the guide than where I started the cut. It pushes far enough right that the friction is too much and the wood starts smoking. I am cutting 3/4" birch plywood and I also tried 3/16" hardboard (I was trying to make a jig). I tried several different things (different blades, different guides, different wood) but they all yield the same result). The saw is Milwaukee 6268 (http://www.amazon.com/gp/product/B000EQAY6K/ref=oh_o01_s01_i00_details) which i think is a pretty decent jigsaw. I used the recommended setup for making clean cuts in wood. 0 orbital action and the fastest speed. Any suggestions or possible ideas on what I am doing wrong? Thanks! Quote
Eric. Posted January 8, 2012 Report Posted January 8, 2012 It's very difficult to make perfectly straight cuts with even the best jigsaw and a solid straight edge. Pick up a circular saw and a blade made for plywood. If you're needing to make a stopped cut, you can do most of it with the circ saw and finish with the jigsaw. The jigsaw is primarily for roughing out curves. Quote
Dave's Not Here Posted January 9, 2012 Report Posted January 9, 2012 It's probably the quality of blade you're using that is giving you fits more than the jigsaw itself. I would suggest you try some Bosch T234 Progressor Blades which you can get at HD. Quote
rmac Posted January 9, 2012 Report Posted January 9, 2012 It sounds like the blade isn't cutting parallel to the side of the shoe of the saw. This is probably just the nature of the beast, similar to the way that bandsaws have drift that has to be accounted for. If you put your guide on the left side of the saw instead of the right, I suspect that the entire saw will try to pull itself away from the guide. That will solve the smoking wood problem, but still won't give you the straight cut you want. Here's what I would try: 1. Look to see if there is some adjustment on the saw that turns the blade so it cuts parallel to the shoe. I looked online in the instruction manual for your saw and didn't see anything, but you never know. 2. Get a blade with lots of set in the teeth. This might let the saw follow the guide even if the blade is slightly crooked. Or it might not. It's worth a try. 3. Forget the guide, and just draw a line on your wood where you want to cut, then learn to follow that line with the saw freehand. This will take some practice, but in the long run it's probably the surest path to success. Learning to follow a line freehand will also be good practice for someday when you want to cut curves with the same saw. As Eric noted, your cuts won't be perfect no matter what you do, so don't feel bad if you have to clean things up afterward with a plane or some sandpaper or a file. -- Russ 1 Quote
ADrywallScrew Posted January 9, 2012 Report Posted January 9, 2012 If you don't mind spending a few more bucks, a circular saw would be my choice. I got a basic Skil circular saw from lowes as a gift and bought a 60 tooth finishing blade. Working with a straight edge and the finishing blade, I can get reasonably straight cuts with minimal chip out in plywood. You can get a saw and a finishing blade for less that $100. Quote
aschaeffer Posted January 9, 2012 Author Report Posted January 9, 2012 wow, thanks for the quick responses! I am going to try going the opposite direction and see if the saw tries to pull away from the guide. A circular saw may be the way to go but will be my last resort as I would like to finish the project without buying new tools. Quote
tdale51@yahoo.com Posted January 9, 2012 Report Posted January 9, 2012 I thought the whole reason for doing projects was to give us an excuse to buy more tools. 1 Quote
duckkisser Posted January 9, 2012 Report Posted January 9, 2012 i see circular saws at garage sales all the time. they might be older but their such a simple tool that they are easy to get to new set up but for 20 bucks i bought a old craftsmen and it works better then the new one i bought(not saying much since there quality has gone down). if your looking to save on a circular saw buy at at garage sales it was a must have for every old contractor and home owner from my dads generation so there are lots out there. Quote
aschaeffer Posted February 15, 2012 Author Report Posted February 15, 2012 Thanks for your thoughts guys. I was actually very lucky and was able to find a used Festool TS55 with guide rail for a reasonable price. I am very happy with the results and will post some pics of the finished product soon. Assembly and finishing next! Thanks again. Quote
rodger. Posted February 15, 2012 Report Posted February 15, 2012 wow - good score! Going from a jogsaw with a straight edge to a Festool track saw is a big step up! Quote
