Hello ,
I am looking to buy a new planer that is 15" or larger.
I am currently looking at the Grizzly 15" planer , which seems to have good reviews and is priced well.
I don't want to spend more than 1500$.
Anyone have any opinions for me.
Thanks
Does it have to be new? If you could find a good used Powermatic that would be the way to go. I had a grizzly 20" planer and didn't really like it much. I spent more time adjusting it than using it. That was just my experience though I know a lot of people very happy with their grizzly's. Another option would be the delta 15 inch planer (which they apparently stopped making)...the new Powermatics are expensive. Which 15" planer are you looking at from grizzly? The one with the Helical head would be your best bet but just over 1500.
All 15 and most 20's and 22's are not without their share of issues. 20's have less issues just do to the mass and pressure bar not found on 15's. Your budget is low for a planer of any real quality or size. I would opt for a straight knife 20" vs a 15" helical any day if cost were a factor. The reality is that even th $4K powermatic 20" is not without its own issues. Unless you get into something like a felder or even the low end twin head oliver your going to get real close to the same planer no matter what brand you buy.
Don
Don
Don, I'm going to get a larger planer at some point. What issues are you referring to?
I tried to upload a photo but the uploader doesnt seem to be working. It really boils down to the 15", 20" and even the 22" are light duty machines. They may seem heavy by hobbiest standards but in terms of planer they are light. They all use a serated spiral cut infeed roller and a semi smooth metal outfeed roller. The 20" and larger use a pressure bar in addition to the rollers. Overhead planers by nature lift the wood off the table. This means the head need to exert some serious pressure to the wood and table to keep the surface flat. Without pressure you get chatter and snipe. Higher end planers put alot of pressure on the wood, with narrow thick stock probably enough to break the table on a PM" 20" planer. Every issue with these lower cost planers revolves around lack of pressure, poor machining and lousy table design but on the other hand you get what you pay for, even the smallest felder cost more than double that of a 20" PM.
Don
I just bought the g0453x with the spiral indexed cutter head and I can tell you that in planes curly and figured wood with 0 tear out
And is a very nice machine
  • Who's Online   2 Members, 0 Anonymous, 52 Guests (See full list)
