riedlj Posted July 22, 2012 Report Posted July 22, 2012 I currently have a JET Planer with a helix cutter that lets me work on wood up to 14.5" wide. My question is weather to look at a wider planer or a drum sander? i am currently working mostly on end grain cutting boards/counters and various different tables with end grain hardwoods. Will a drum sander let me plan my projects at the 14.5" and join them and use the drum sander to "hide" the seam?? What is the BEST drum sander out there? Quote
Vic Posted July 22, 2012 Report Posted July 22, 2012 I would definitely NEVER run end grain through a planer or over a jointer. That's a recipe for a major disaster. A drum sander will take longer, but is at least a safe method. Quote
HuxleyWood Posted July 22, 2012 Report Posted July 22, 2012 If you are looking for the best drum sander the Woodmaster sanders are about as close to a wide belt as a drum sander gets (still a big difference though). The Woodmasters are built in the US. Quote
toddclippinger Posted July 22, 2012 Report Posted July 22, 2012 You need the drum sander for sure with the projects you are doing. Quote
riedlj Posted July 22, 2012 Author Report Posted July 22, 2012 I think we are going to look at the JET 22-44 OSC Drum Sander. Does anyone have any input on their drum sanders. Quote
wdwerker Posted August 2, 2012 Report Posted August 2, 2012 I have the Performax 16/32 and end grain cutting boards are possible. You have to take light passes and keep the sandaper clean. If you let resin build up you can get a burn. Quote
