CT Proctor Posted December 8, 2012 Report Posted December 8, 2012 I was at work earlier this week and was complaining to one of the Engineer's about all the racket my air compressor makes. He said all I had to do to significantly reduce the noise was to pipe the air intake outside, becuase a major source of the noise is the air trying to rush into the intake. So this afternoon I picked up the supplies I needed and drilled a hole in the side of my shop wall. All I can say is wow, it probably cut the compressor noise by 50%. Outside it sounds like there is a Harley idling. I will still probably wall it off but it did make a big difference. Air intake pipe through the wall. Intake filter on outside of building. Quote
dcustoms Posted December 9, 2012 Report Posted December 9, 2012 Looks Great Chris! That's really cool that it worked so well. I do have a little air compressor envy...even though my is quite large by most standards! Quote
wdwerker Posted December 9, 2012 Report Posted December 9, 2012 Great idea but my compressor is 40 ft from the outside wall! Wonder if moving it up 12 ft towards the ceiling would help. Quote
Jfitz Posted December 9, 2012 Report Posted December 9, 2012 That's a great idea. Nice job on the installation! Don't forget that the outside air will be pretty humid in the summer, so you'll get a lot of water in your tank. Empty it frequently. Quote
CT Proctor Posted December 9, 2012 Author Report Posted December 9, 2012 Yes, big compressor. 60 gallon, 5 hp, dual stage. @ Steve - The Engineer also told me that if I ran over 10' I had to double the pipe size. @ John - Thanks for the reminder, the compressor is piped around the shop and there's already a drain line run outside. So all I have to do is open a valve to drain. Quote
Danny Hellyar Posted December 9, 2012 Report Posted December 9, 2012 great Idea. I'd like to do this as well ,but then I think the neigbors might complain about the noise. Quote
