jbs550 Posted January 26, 2013 Report Posted January 26, 2013 I know that this is going to seem like a complete noob issue (which I am sure it is), but I just can't seem to get my jointer (8" grizzly) to flatten an edge/face the way it should. Fence is square, helical cutterhead is all sharp, but I can run an edge that is bowed over it multiple times and it will still be bowed. Same with doing a face. Can anyone tell me what the heck I am doing wrong? am I putting too much pressure in the middle? on the ends? just in general? I am getting really frustrated. Probably been screwing it up for the entire last year that I have been doing this hobby, but just am finally getting to the point where I notice it not being perfect. TIA, Jim Quote
estesbubba Posted January 26, 2013 Report Posted January 26, 2013 Joint a couple of 4' boards and put the edges together like you are going to glue them. How big is the gap? Quote
TRBaker Posted January 26, 2013 Report Posted January 26, 2013 Jim, jointers can be frustrating some times, even for us old-timers. Marc has a really good video on Wood Whisperer on setting up and tuning your jointer. I highly recommend it. Start with the set-up first and if everything checks out, then you can look at technique. Something as simple as picking up your jointer and moving it a few feet can throw one or both of your tables out of alignment. Quote
Eric. Posted January 26, 2013 Report Posted January 26, 2013 Are you jointing smiley face or frown? Quote
jbs550 Posted January 26, 2013 Author Report Posted January 26, 2013 bubba, not much, maybe 2mm? Troy, Marc's video (assuming you mean "the jointer is jumpin') is what I used to "learn" (whether that is a true statement or not) to use my jointer. Unfortunately, my jointer is very difficult to adjust the beds, but they are very close to perfect. I have a veritas 48" aluminum straight edge that I finally gave up and bought to use to set it up to make sure. I think there is more vibration than maybe there should be, and I may replace the belt with a v-belt to help. I just can't convince myself at this point that it isn't my own fault running the board, though it seems like that should be relatively easy. I tell you, I love woodworking. started back up a year ago, after not having done any since HS. Marc, through the guild as well as email, has been a miracle helping me learn to do it, but I still have so many issues. eventually, maybe I'll get it. appreciate the thoughts, guys/gals, please, keep them coming. Quote
jbs550 Posted January 26, 2013 Author Report Posted January 26, 2013 eric, frown. do I need to do it the other way? Quote
TRBaker Posted January 26, 2013 Report Posted January 26, 2013 Jim, I usually join the convex side by taking a little out of the middle first and then running the full length. Just make sure to keep your pressure on the out-feed side of the jointer instead of the in-feed side, once the board gets started. If you put the downward pressure on the in-feed side, you can actually see the board follow the bow and lift off of the end of the out-feed table. Quote
jbs550 Posted January 26, 2013 Author Report Posted January 26, 2013 I always try to keep the pressure on the outfeed side. How much pressure do you put down just in general though? Does it need to be light pressure, or moderate/heavy pressure. I know this sounds a bit crazy. I really wish I could find a CC course or something in the area, but there is nothing in the el paso area at all, seemingly. Maybe I just need to flip the board, and joint the convex edge first. Quote
Nick2cd Posted January 26, 2013 Report Posted January 26, 2013 It really depends on board length. Short boards are easier to joint. If the length of your board exceeds the length of your indeed table, you want to run it as a smile. Reason being, if you run it as a frown and some of the board is hanging off the infeed table the the angle will change when the tail end of the board gets up onto the infeed table. Run it as a smile and create a flat spot in the middle. Keep passing it over the knives to expand the flat spot until the flat runs the entire length of the board. You really just need enough pressure to keep the board secure. Don't push down hard the last thing you wanna do is flatten the board to the table from down pressure and then run over the knives. That's what the pressure roller of a planer does, hence why u can't joint a board in a planer. One last thing....your outfeed table should be level with your knives or a couple thousandths under the level of the knives. An adjustment of just a few thousandths here can make all the difference in the world. Quote
jbs550 Posted January 26, 2013 Author Report Posted January 26, 2013 Thanks Nick. I bet that is my main problem. The boards are usually longer than the infeed table. Appreciate everyone's help. should have asked a long time ago... Quote
funwoodworking Posted January 26, 2013 Report Posted January 26, 2013 I was running into the same problem with long boards too, with my 6" grizzly, I found the best way to remedy this was after the board was about 6" onto the outfeed table, too then keep both hands on the outfeed side of the board and continue to pull the board thru. If the board has too much bow, and is too long for the infeed table, then it would be better to run it thru the saw, then back to the jointer. Quote
jbs550 Posted January 27, 2013 Author Report Posted January 27, 2013 so, I just realized that I accidentally put 8" in my OP. It is actually a 6" jointer. I went back and checked my tables again, and the infeed table pointed down so that when you put a straight edge on the outfeed table flat, and raise up the infeed table, the very beginning of the infeed table touches the straight edge and there is a gap at the cutter head. So, I looked up how to shim the outfeed table to get them completely coplanar. Was clearly not a good idea. I still get the scooping in the middle of the board, and now it tapers the board from front to back and I ruined a nice, highly figured curly maple board before I realized it was happening. Rechecked the outfeed table to make sure it was level with the cutter head. It is. Still does the taper thing. I'm about to just throw the damn thing away and buy a powermatic. SO FRUSTRATED. Now I don't even have a barely usable jointer, let alone one that works correctly. Quote
TRBaker Posted January 27, 2013 Report Posted January 27, 2013 Jim, if a board is really bad, I will sometimes chalk a line and then rip it with a circular saw before jointing. Quote
jbs550 Posted January 27, 2013 Author Report Posted January 27, 2013 I thought I had it figured out, which is why I went back to trying to mill the board I needed to finish the project that I am working on. bad decision. Not sure what you mean about a dial indicator for the outfeed table alignment. The head is helical, so I don't know if that matters. I have a 60" aluminum veritas straight edge that I use, that is it. I never had a problem with the tapering until I shimmed the outfeed table, which was the only way the grizzly support people could tell me to fix the coplanar issue. Think I am going to take the shims out of the outfeed side, and try to shim the infeed table. I don't move it really anyway, so it should't matter. Been doing this for over a year now, and it took me a few months to really figure out how to get the TS dialed in, then even longer for the bandsaw, but I just can't seem to get the jointer to work completely correctly at all. When I get something new (which I plan to after my next and hopefully final move in 6-12 months) I am going to get something that is easier to adjust. Quote
Eric. Posted January 27, 2013 Report Posted January 27, 2013 Hey Jim, here's the video that TR was talking about. http://youtu.be/gO746cuRqV4 Quote
dwacker Posted January 27, 2013 Report Posted January 27, 2013 Not sure what you mean about a dial indicator for the outfeed table alignment. The head is helical, so I don't know if that matters. I have a 60" aluminum veritas straight edge that I use, that is it. I never had a problem with the tapering until The clue here is tapering. Your tables may be perfect and you will get tapering. Look at the your boards. If you cut frown down you will taper. If you have a big frown you don't want to just run the board across the jointer frown down. You would cut part way removing one side of the frown, flip the board around and do the other side. If you cut frown up you balance the board on the arc of the smile on the first cut making a flat spot. Frown down or up depends on the wood grain. Don Quote
estesbubba Posted January 28, 2013 Report Posted January 28, 2013 I have all my big machinery well tuned and this book shows you how to do each machine. Nothing is more frustrating than having machinery that isn't working as expected and this book makes tuning easy. http://www.amazon.com/Care-Repair-Shop-Machines-Troubleshooting/dp/156158424X/ref=sr_1_1?ie=UTF8&qid=1359341017&sr=8-1&keywords=Care+repair+shop+machines Quote
stahlee Posted January 28, 2013 Report Posted January 28, 2013 If you're creating wedge shapes when jointing, drop the outfeed table just a hair below the cutterhead. That will stop that. I always run frown through the jointer. Just be careful like others said about catching the lead edge between cutterhead and outfeed table. Just push it through lightly without pressure to get past the edge. Once you get to the bow, the cutterhead will not be touch the board, so push through until it does. Do this several times and then flip the board around and you'll be able to run it over easily with the jointed half first. All this in the frown configuration. Hope that makes sense. It will make quick work of a bowed board. chris Quote
