amateur eric Posted May 1, 2016 Report Share Posted May 1, 2016 I have a craftsman circular saw that I've been using for almost all of my cutting so far. It was a gift from my parents. But they don't know a whole awful lot about the nice brands, but it's all I got for now. Once I make a few things and sell them and get more cash, I'll slowly start acquiring better quality tools. Mostly it's been to cut pallet wood to length. Here lately, it hasn't been wanting to cut through the wood, which is only about 1/2" pine. I'll get partway through my cut and the blade just stops spinning, but the saw is still running. And it's been causing burn to the cut as well. Any ideas what the issue may be? Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Llama Posted May 1, 2016 Report Share Posted May 1, 2016 If the blade is not spinning and the motor is, the blade retention nut may be loose. Seems that it's stopping when it gets under load. Quote Link to comment Share on other sites More sharing options...
amateur eric Posted May 1, 2016 Author Report Share Posted May 1, 2016 If the blade is not spinning and the motor is, the blade retention nut may be loose. Seems that it's stopping when it gets under load. Good call. I tightened the nut and it didn't lock up. Still burned a bit, but I believe that's due to a dull blade. Quote Link to comment Share on other sites More sharing options...
wdwerker Posted May 1, 2016 Report Share Posted May 1, 2016 Sharp blade will cure that. In the mean time clean your blade. If you don't have any blade cleaner many strong household cleaners will do the job. An old toothbrush works well. Quote Link to comment Share on other sites More sharing options...
wtnhighlander Posted May 2, 2016 Report Share Posted May 2, 2016 Even just a soak in hot water, with a touch of dish detergent, will loosen most pitch buildup so that it scrubs off easily. Quote Link to comment Share on other sites More sharing options...
