I have two questions I hope y'all can help me with. First is about sharpening. I bought this Stanley #82 scraper for $20. See the pictures below. How do I sharpen the blade? Like a card scraper with a file and burnisher or another way?
Second, I want to buy a hand saw. I make small projects - jewelry boxes, picture frames, shadow boxes, etc. For example tonight I was cutting some 1/8" splines for miter keys. I know I could have used the bandsaw but its overkill and time consuming. I ended up cutting them to size with a flush trim saw which worked but thought that using a handsaw with a bench hook would have been much better, not only for this but also picture frames or other smaller miters. I don't really like cutting them on my 12" sliding miter saw. I'm looking at Veritas saws. Standard crosscut, gent's crosscut? Rip instead of crosscut? I'll eventually buy a dovetail saw when I learn to hand cut those, but for now, what's your recommendation?
post-7016-0-17745800-1366337118_thumb.jppost-7016-0-17264200-1366337131_thumb.jp
Don't know about the scraper but for what you describe for sawing I'd say get the 11" carcass saw in xcut.  The extra couple inches will give it a good bit more versatility over the smaller gents and xcut dovetail sized saw.   It is still a small fine joinery saw and should be perfect for what you describe.  If you really want something for only exceedingly fine xcut work than you might be better of with an xcut dozuki. I use western saws almost exclusively but for very very fine xcuts is hard to beat a dozuki.
I was going to make the same comment about the scraper.  I use ones like that for scraping paint.
As far as miter keys, I think I'd have to define your terminology before I can answer - do you mean a spline that is integral to the joint, inside it to help align the miter, or splines that are cut across the outside to add glue surface to strengthen the joint?  Do you have a table saw?
I was going to strike up a thread looking for some hand saw advice.
Ow that I have a starter power tool set up, I wanted to start focusing on some key hand tools. I have decent chisels, a #5 and #3 plane that I am cleaning up, plenty of rasps and file, but I am woefully short of hand saws. I have a dewalt crosscut saw with huge teeth on it that makes short work of 2x4s but I am certainly not going to use that for making furniture or cabinets. If you were going to get 3 or so saws and spend $200 or less what would you go with?
Carcass crosscut, dovetail, and flush trim?
  • 3 weeks later...
Roy used a big old Stanley miter saw to make the splines in "The Eleven Grooved Box" which you can view on line.  He cleans up and sizes the spline with a simple block that has a couple of appropriate grooves plowed in and a block plane.
  • Who's Online   2 Members, 0 Anonymous, 45 Guests (See full list)
    Bob44
    Bob44
