I am in the process of installing a separator on my new dust collector. I got the Woodcraft lid:
http://www.woodcraft.com/product/2004310/8981/trash-can-cyclone-lid.aspx
and was planning to attach it to the 50-760 with this 5"->4" reducer:
http://www.woodcraft.com/product/2000899/39345/5-to-4-reducer-dust-collection-fitting.aspx
but the 5" side is too small to attach to the Delta. Do I really need a 6"->4" (it seems like that would be too big)? Or is this called something else besides a "reducer" to get a 5" "thing" that fits correctly?
Thanks,
David
It looks like the reducer is supposed to fit inside a 5" port or hose.  I don't know about the Delta but a lot of times there's a grill on the port that is supposed to keep big stuff out of the impeller.  Is that keeping you from inserting it and you expected it to fit over the port?  If so you can either cut out the grill or use something else to connect the adapter to it.  A short length of 5" hose would work but 5" hose is pretty expensive.  You would actually be better off running 5" hose to the separator and then reducing it there though.
I have the same DC, I used a metal duct (HVAC) 5->4 reducer which I got at home depot. It went on over the 5" port (not into it) - t was a tight fit but it works. That DC is supposed to come with a "Y" that splits the 5" into 2 4" ports.
krtwood - the 5" port on the reducer seems to be exactly the same size as the port on the DC - it doesn't fit inside or outside.
John Ftiz - It did come with the "Y", but the Y is too tall to fit with the trashcan. I'll have to check out HVAC reducers at Home Depot - thanks.
