Help needed finding bastard cut walnut
I’m hoping to start the little shaker table from Schwarz’s new DVD. I have some walnut that should work well for most of the project. One thing I don’t have (and don’t know how to find) is the bastard cut stock he calls for for the legs. Where can I get that? (I’m not blessed with a good hardwood supplier that I’ve found in the Manhattan, KS area).
Bonus question: anything I should look for in it?
Bastard sawn is where the rings are at ~45* to both the face and the edge.
There are a few ways to get it from thicker plain sawn.  If these were rotated they would look like the rings on plain sawn (((.  On either edge of the board the rings will be close to 45* relative to the face and edge.  Additionally depending on the thickness available you can use the middle of the board, by ripping it at an angle when looking at the end grain you would cut out a square diamond [_____<>___].  There's a bit more waste this way but you get the consistent grain you are looking for.
Basically look for fairly straight grain.  Unless you want to exaggerate the taper and have the grain follow the angle taper instead of the straight side.
You have to go looking through the piles. Bastard cuts you get from the first few boards away from the center. For example if you cut a tree flat sawn the very center board will be quarter sawn. The few boards either sided of center will be bastard cut. Some people just call it rift sawn.
Thanks. so rift-sawn = bastard cut (like the former better).  Since I don't have access to searching the piles, can I tell the wood store what I need?  Going to go have to do some research on mail order wood.
You might want to add your location. Someone may have a source close to you.
If I remember right that Shaker table has pretty thin legs; like 1 1/8.  In which case you can work rift saw parts out of most 8/4 stock by cutting at an angle as mentioned above.  There aren't many yards that will go find rift sawn for you but it can't hurt to ask.  I'm sure I have some on the rack if you let me know how much you need.  http://hardwoodtogo.com
For a small leg like that, start with 6/4 or 8/4, and use a small square template (made out of paper or scrap) that represents the cross section of the leg; hold it on the end of the board to find a good location for the grain you want.  Mark the outline of the square and then use the BS or TS to rip it off at whatever angle is needed.
The legs are 1 1/8 inch square and 28" long approximately
Thanks Shannon.  If ya gots something that would work for me let me know.  Enjoy the blog btw, was watching a video on it this morning.
Tony - check out this article (by Chris Schwarz) from Popular Woodworking, on building a Shaker end table
http://www.popularwoodworking.com/wp-content/uploads/2010/10/HiRes-SEPT2004-Seg2.pdf
The second page of the article deals with this exact issue - how to cut a leg from a larger (thicker) board in order to get good grain direction.  They even mention 'bastard grain' - I had never heard this term, but you learn something every day. Note - the key is that you start with a much thicker baord.  So if your legs need to be 1 1/8" square, which is just under 5/4, you might need to start with a 6/4 or even 8/4 board.  Read the article, it'll make sense.
EDIT: I just re-read and saw that you are basing your table on Schwarz's DVD.  I'm not familiar with the DVD, but seeing as he also wrote the article I would be surprised if he doesn't cover that same technique for bastard grain.
Marc has a Guild video on building this table and he shows very clearly how to cut the legs from 8/4 stock. I think the article referenced above also describes how to do it.
I had to go and check the Guild project, and this article is actually part of the Resources for that build. I know I had seen it somewhere :)
FWIW the current issue of Wood magazine (July 2013 issue) has an article that is very similar, about how to get the most out of home-center lumber. The idea is to buy boards much larger than you normally wood - for instance, maybe a 2x12 - and cut/mill it efficiently to get the best boards out of it.
Thanks for the article John Fitz.  It looks like the same table but he didn't go into the detail on rift sawn acquisition - perhaps because it's harder doing everything by hand which is what the DVD is focused on.
BTW, My Dad used to work for Codex (later Motorola Information Systems Group) and used to go to Mansfield every summer to train on the new equipment.
Codex - wow, that goes way back. They (and then Motorola) were a major employer in the area at the time.
