Tpt life Posted June 28, 2013 Report Posted June 28, 2013 This was my test. This plane sat in a shallow dish of white vinegar for about ten hours. I wiped it off with a rag. It is plainly obvious how much of the casting was under the surface. I should add, the castings seem to rust more slowly and on the surface. The iron did not clean nearly so well and will need further treatment. Quote
Spencer_J Posted June 28, 2013 Report Posted June 28, 2013 Wow! Serious results. Vinegar is amazing. Quote
mds2 Posted June 28, 2013 Report Posted June 28, 2013 i never knew vinegar would do that. Now I can start buying crappier planes! Quote
haysflooring Posted June 28, 2013 Author Report Posted June 28, 2013 I'm very impressed. I never dreamed vinegar would work that well ! Quote
Tpt life Posted July 10, 2013 Report Posted July 10, 2013 I have some additional imagery for you. I am not sure I would vinegar soak for longer than 24 hours except when necessary. At about 30 hours this off gassing and convection can be seen. Please forgive the video, I was not thinking of sharing this when I shot it. The metal surface rusted very quickly in the humidity after the long soak. I would oil the metal very quickly after the soak. Some scrubbing was still necessary but was so much easier to deal with post soak. Quote
