h3nry Posted July 14, 2013 Report Posted July 14, 2013 I've been enjoying using veneers to accent projects, so a logical extension was to try a bit of marquetry. This is my first attempt, with a simple flower-in-a-pot design. It is made from walnut and cherry set into maple. A little sand-shading would probably have improved the leaves a bit, but that is a technique I'll tackle next time. After having made the small practice panel, like Marc with his carved spiral, I had to find a use for it. So I built a box round it with a scrap piece of walnut, resawn and bookmatched to get a continuous grain pattern on all edges. For a quick weekend project designed on the fly, I think both the box and veneering turned out ok. 1 Quote
jhl.verona Posted July 14, 2013 Report Posted July 14, 2013 For a quick weekend project designed on the fly, I think both the box and veneering turned out ok. So do I. For a first time marquetry project, I'd be exceedingly pleased with myself! Well done Henry - what is the size of the box? John Quote
TRBaker Posted July 15, 2013 Report Posted July 15, 2013 Great job, especially for first time. Keep it up. Quote
h3nry Posted July 15, 2013 Author Report Posted July 15, 2013 For a first time marquetry project, I'd be exceedingly pleased with myself! Thanks. Of course, I am pretty pleased with it - which is why I posted it here. the box is only 6 inches square - so not a big project. I didn't do a great job resawing the wood, so by the time I had planed out my saw marks it was less than 3/8 thick. The biggest lesson I learnt with the marquetry was ... use flat veneer. Do whatever it takes to make it flat before starting the cutting and taping. And also it seems that in the final result, the organic shapes of the flower and leaves are more forgiving of errors and asymmetry than the geometric shapes in the vase. Quote
h3nry Posted August 6, 2013 Author Report Posted August 6, 2013 Take-2 Here's my second attempt with some hot-sand shading. The shading really adds depth to the design. It took a bit of getting used to to, and is hard to judge the right amount of shading. It also makes the wood quite brittle and I burned a couple of pieces beyond use. This piece found a home replacing the plastic cover on my doorbell chimes. 1 Quote
Tpt life Posted August 6, 2013 Report Posted August 6, 2013 H3nry I find the artistry tremendously appealing. Well done! Quote
TRBaker Posted August 6, 2013 Report Posted August 6, 2013 Outstanding H3nry. The possibilities are endless. Quote
