Chuck Melton Posted October 3, 2013 Report Posted October 3, 2013 Running a short over the jointer so you can take it to the hardwood dealer to try to find something that is a close match is a horrible idea. Luckily, I just need a new push paddle and not new fingers. Hopefully the wife probably won't notice the dent on the garage door. Quote
Boatworks Today Posted October 3, 2013 Report Posted October 3, 2013 Whoa, good to hear you still have all your digits! Quote
Chuck Melton Posted October 3, 2013 Author Report Posted October 3, 2013 I think I had just gotten too comfortable with using the machine and just wasn't thinking whe I tried to face joint a 6" piece of wood. I am sure I read somewhere not to win anything less then 24" over the jointer but it must not have sunk in. I just wanted to post so that any other novices like myself could have a reminder. Quote
duckkisser Posted October 3, 2013 Report Posted October 3, 2013 I find that you can do shorts you just need a wide push stick to spread out the pressure. Quote
pghmyn Posted October 3, 2013 Report Posted October 3, 2013 Shorts are doable, but not preferred. Glad you didn't put a flat surface on your fingers Quote
dwacker Posted October 3, 2013 Report Posted October 3, 2013 I think I had just gotten too comfortable with using the machine and just wasn't thinking whe I tried to face joint a 6" piece of wood. I am sure I read somewhere not to win anything less then 24" over the jointer but it must not have sunk in. I just wanted to post so that any other novices like myself could have a reminder. You can certainly go much less than 24". Sounds like you just tipped into the cutter. To much pressure on the leading edge. 1 Quote
wdwerker Posted October 5, 2013 Report Posted October 5, 2013 I would have needed some clean shorts after that...... 1 Quote
JoshC1501 Posted October 5, 2013 Report Posted October 5, 2013 I have not had a close call with my jointer, but I am very carful. Something about it! It is a nasty looking piece of equipment when you starting thing about life after getting you fingers/hand to close to the cutter-head. Josh Quote
TerryMcK Posted October 5, 2013 Report Posted October 5, 2013 Close call - glad it's just the garage door that was dented. Quote
