chrisphr Posted February 2, 2014 Report Posted February 2, 2014 My powermatic tablesaw (that I bought used) doesn't have a splitter and after experiencing kick back up close and personal want to add this feature. Looks like the Micro Jig pro is the way to go. Does anyone know if the micro jig splitters will work with a shop made insert? Also what are your opinions regarding shop made inserts vs store bought? I like the idea of making the inserts because I can batch out a bunch of them so will have spares and also available for bevels and dados of various widths. That said if there is a significant performance difference, I will go for store bought. Thanks! Quote
rodger. Posted February 2, 2014 Report Posted February 2, 2014 The micro splitter requires a shop made insert, at least the version I have. I have the "non pro" model, tin kerf. It came with directions on how to make a jig and came with the drill bit required to drill the holes. Works well. I make my inserts out of laminate flooring scraps, but MDF would work fine too. Just make sure you level the insert to the table top using tape, screws, or whatever levelling method you desire. If the insert is not flush with the table, it is a real hazard, as your material can get caught up on it. Here is a pic of my insert with splitter installed. 1 Quote
lighthearted Posted February 2, 2014 Report Posted February 2, 2014 You can install on any zero clearance insert. As Franklin Pug said it comes with directions and a kit for installation, you need a piece of MDF for this install if i remember correctly. I recently upgraded to a saw stop with a riving knife--but the micro splitter worked great in my old table saw and certainly saved me on some moist, curvy wood. it a worthwhile purchase. Quote
Scott Keith Posted February 3, 2014 Report Posted February 3, 2014 I don't have a micro jig, but I do use shop made insert plates almost exclusively. I have made them in different ways, but I now have access to a ShopBot CNC router, which makes short work of insert plates. I see no reason to purchase them other than simply not having the time to make your own. With limited shop time, "store bought" is always an option. Quote
krtwood Posted February 3, 2014 Report Posted February 3, 2014 In my experience MDF was too flexible on its own. It would be fine for working with sheet goods and what not, but anything where you're having to put any downward pressure over the insert there was just too much flex for my liking. I still have an MDF dado insert that I had added some hardwood strips underneath to stiffen it. I use baltic birch, either 12mm or two layers of 6mm glued together which I then run through the drum sander because it's a little too thick for my saw. The problem though is that while we like to think of MDF and plywood as being dimensionally stable it DOES change thickness with changes in humidity. It's enough to require shimming when my shop goes from the ~50% I hold it at during the summer to the ~20% of the winter. I wouldn't use the plastic micro jig, it just ripped right out of the insert when I had a piece close up hard on it. Worthless. Quote
Scott Keith Posted February 3, 2014 Report Posted February 3, 2014 I made a couple of splitters out of metal that attach to the same mounting block as the original splitter/guard assy. They are pretty easy to put in or remove and they will bevel with the blade, something the Micro Jig can't. What PM saw do you have? I have a Jet cabinet saw which shares a lot of common parts with the PM cabinet saw of the same vintage. If we have similar saws I would be happy to send you pics of my set up. Leme know. Quote
dwacker Posted February 3, 2014 Report Posted February 3, 2014 I just use the Leecraft. They last longer than wood or mdf. Quote
chrisphr Posted February 3, 2014 Author Report Posted February 3, 2014 I made a couple of splitters out of metal that attach to the same mounting block as the original splitter/guard assy. They are pretty easy to put in or remove and they will bevel with the blade, something the Micro Jig can't. What PM saw do you have? I have a Jet cabinet saw which shares a lot of common parts with the PM cabinet saw of the same vintage. If we have similar saws I would be happy to send you pics of my set up. Leme know.At work so can't directly check, but I think it is model 64a, contractor saw. Here's a pic. Everyone, thank you for your thoughts and ideas! Quote
rodger. Posted February 3, 2014 Report Posted February 3, 2014 In my experience MDF was too flexible on its own. It would be fine for working with sheet goods and what not, but anything where you're having to put any downward pressure over the insert there was just too much flex for my liking. I still have an MDF dado insert that I had added some hardwood strips underneath to stiffen it. I use baltic birch, either 12mm or two layers of 6mm glued together which I then run through the drum sander because it's a little too thick for my saw. The problem though is that while we like to think of MDF and plywood as being dimensionally stable it DOES change thickness with changes in humidity. It's enough to require shimming when my shop goes from the ~50% I hold it at during the summer to the ~20% of the winter. I wouldn't use the plastic micro jig, it just ripped right out of the insert when I had a piece close up hard on it. Worthless. That surprises me. I have had the plastic one for years now, and it works great. Quote
dwacker Posted February 3, 2014 Report Posted February 3, 2014 Check with shark guard they may make a real metal splitter for your saw. Quote
JMort847 Posted February 4, 2014 Report Posted February 4, 2014 I use the Micro Jig Pro splitter on shop-made Baltic birch and MDF ZCIs with no problem. I prefer shop-made because you can have process-specific inserts - like 45-degree angle, dados, etc. Quote
Spencer_J Posted February 11, 2014 Report Posted February 11, 2014 I just use the Leecraft. They last longer than wood or mdf. me too. i use the MJ splitter steel pro for it's low profile. i'm using an old unisaw. gets very consistent results. Quote
