Building a 5 inch thick top for my bench and am in the process of setting up the tilt bracket. The bracket has an insert for the bar to go through and clamp against, but I can't seem to get enough play to allow a full 90 degrees of range.
Posted Image
For others who have this installed, how deep does the mortise need to be, and how far from the vise itself? Any measurements would be appreciated. In my case it seems like I need to make a 4" deep mortise for the bracket, which doesn't seem right. I'm thinking of angling my mortise so that the guide bar is 90 degrees to the bracket instead so I don't have to go so deep.
Solved it. I ended up making my mortise about 2" deep and then slightly angled the bottom. Everything moves nicely with no binding.
Posted Image
However anyone looking at this for reference in the future, be sure to leave enough of a gap for the bolt on the tilt bracket so that it doesn't interfere with the base. I had to hog out a relief for the bolt and allow me to remove the top on the future.
Posted Image
Installed and waiting for me to make a handle so I'm no longer using a plunger handle.
Posted Image
