I have a pin nailer and a brad nailer.  I've been looking to pick up a larger nail gun.  Can't really find an overall tutorial on nail gun sizes and uses, etc.  I'm designing a new pressure treated privacy fence.  Good excuse to by a nail gun.  Friends have recommended spiral guns, etc.  My quetion is I'd like a gun that works for the fence build but will also serve me for other purposes down the road.  Any suggestions?  Also, what type of nails would you use for treated lumber?
Nailgun nails don't hold long term outside.  I have a bunch of nailguns.  For PT stuff, I use Deckmate "star drive" screws from Home Depot.  I'm still replacing nailgun nails in our mile of horse fence.  I walk the fence a couple of times a year, pull any nails that have backed out, and replace with screws.  This fence is 20 years old.  All the newer fences have been built with screws, and have required no work since they were built.  The glue on the nails doesn't hold up in this use.
The largest of the finish nailers, 15 gauge, is not substantial enough for fence construction. People do it all the time, don't make it right though. Framing nailers using galv nails will work for the larger timbers, but may be too aggressive on some of the smaller components like the slats, leading to cracks and blowouts. I would just go for exterior screws rated for use in pt wood, hot dipped galvanize nails if you want to be one with nature and hand nail all day.  :P
I built a utility shed a few years ago and used cedar siding. Knowing you shouldn't use galvanized nails on cedar, I found some stainless steel finish nails for my PC nailer. That was around ten years ago and holding up fine. If I remember right they were expensive and I found them online.
Get a coil framer that will shoot ring shank nails for fencing. Coil nailers carry far more nails. Coil framers will shoot both long and short and SS. Pawn shop rehabs are cheap usually only requiring a new plunger and O-rings. Craigslist or eBay it when you are done.
PS- All the newer fences are not being built with screws. They are considered too inflexible and snap often and are far more expensive and labor intensive. If you are seeing that Tom it is regional.
I don't really pay attention to what others are doing, so it's nothing to do with region.  I built our first horse fence, 4 board with 2x6s, and 4x posts, with a nailgun twenty some years ago (actually thinking about it, it's 32 years-thanks old style Salt treated).  I think the nails stayed in good for eight or ten years, then started backing out.  All the newer fencing we've put in (some of it early 90s), we have used various screws.  All the screws are still holding fine.
I don't remember when HD first started selling Deckmate "star drive", but they've been my favorite since then.
An 18 volt impact driver, even with TORX (screwdrive) screws is not as fast as a nailgun, but it goes along fairly quickly.  I know they will stay in, and I can get any one back out if I need to, like hurricanes dropping trees on the fence.
Dock builders here on the lake stopped using nailguns for nails out in the weather a couple of decades ago.  Ring shanks hold good in the wet wood as it shrinks and dries, but even they back out as the wood gets in later stages of it's life when screws would still be holding.
If it can be nailed, and it stays out of the weather, I'm using a nailgun.  I even use them on historic houses when the nail is going to be hidden from view by another layer, so I'm not at all anti-nailgun.
I've never had a single screw snap in the miles of horse fence, even when a tree falls on it, or a car wrecks through it.  Now, some of the old decking screws were nothing more than galvanized sheetrock screws.  I'm sure they will snap, but I've never used them.  The Deckmate heads will pull through the wood before they will break.
I never do a job if the priorities are "fast and cheap", or even waste time talking to a customer who is looking for that.  I wouldn't recommend anyone else use those priorities on a DIY project.
I don't know the design of the fence here, but if you can hang all your boards with a screw on each end, and some in the straight boards, then go along and wedge the crooked ones into place off the straight ones, it goes along faster than putting all the screws in each board as you go.  That's the way we put deck, or dock, boards down.  Then you can run all the other screws in along a line without a lot of body movement, and it ends up saving a lot of time.  Plus, you can go back and put screws in on other days, if it's a home project.
  • Who's Online   1 Member, 0 Anonymous, 44 Guests (See full list)
