blown insulation possible problem
so im looking to blow in insulation into my garage walls.  the problem is that the walls are not covered with dry wall or ply wood.  instead they are covered in solid wood boards.  the strips are 2inches wide and half an inch thick.  im worried that if i try blowing insulation into the walls they will just come out the cracks in the walls between the boards.  so do you think the insulation is big enough that it will eventually fill up the cracks with minimal leaking or will i need to fill the cracks?  if i do need to fill the cracks what will i use to fill the cracks can i just use some spackling
You will be fine. That stuff packs in real tight. I had my house done 25 years ago. During a recent remodel we tore off all the plaster and lathe walls and the insulation just stayed in its own. It does settle so if you blow it in it will settle down over time and the tops of your walls will not be insulated.
Thinking of doing the same in my garage. I suspect you'll be alright, the insulation appears to want to cling to itself and does have some bulk. You might get a little leakage, but perhaps it won't be significant. You'll have your answer after you fill your first wall cavity. The insulation is cheap and machine rental free in some places, you can learn by trial and error.
i figure once it settles ill eather have bought a new house or ill be an old man and just fill it up again.
thanks wasent sure how well it clings to itself.
Have you considered spray foam? Seals the leaks and won't settle. Just a thought. Rodents and bugs won't bother it.
Duck, are you having this done or doing it yourself?
If you're having it done, then the contractor will be able to answer this question for you.
If you're doing it yourself, then I suggest having a contingency plan in place in case it is an issue.
Gaps to 3/4" will fill with some loss. Often the installers will just hold their hand over the gap until the fiber packs. It is a little dusty but not super wasteful.
this is cracks between the boards nothing like 3/4 in fact its rather tight considering the ae of the garage
Just don't use the fine, German white stuff, and it should be okay. If it comes out to start with, here and there, you can just knock it off with a brush.
  • 26,009 Total Members
  • Joseph b Newest Member ·
