A local shop may be going under, which means there could be spoils up for grabs soon. Great timing for me, if you read my 15 vs 20" planer thread from a week or two ago. To get to the point, my intro talks about this machine have lead me to believe it's currently not operable. Either the motor is shot or it's missing. The guy wasn't too clear. In any case, I cant make an offer if I don't know what the cost of getting it running are. This is my plea to the greater woodworking community; can someone send me a photo of the motor plate from their planer? Diameter of the motor shaft? I know that a PM replacement motor would be about $700. That's not bad, but I know diddly squat about what that motor is. Is it some crap Chinese motor? Is it a baldor motor? No one knows, and PM isn't telling! Ive searched google and every forum imaginable and somehow the motor specifics for this machine are classified information. Im thinking I can source a good American made motor for cheaper than PM is going to sell me their mystery motor. Before I do that, I need to know the basics like RPM, shaft diameter, motor frame etc. Thank you in advance!!
Posted (edited)
Manual is here: http://content.powermatic.com/assets/manuals/1791296_man_EN.pdf
Its a 5hp motor with 230volt and 28amps. So its not for the faint of heart.
The only real question is what rpm it is, the diameter of the motor spindle could be figured out by ordering a replacement motor pulley which should be cheap enough. Either way you should be able to call customer service and ask them. If powermatic can't tell you the rpm of their own motor then shame on them.
The make is not important as any motor with similar specifications will do just fine.
This all assumes the motor is either missing or completely inoperable. If the motor is there then it will almost certainly be cheaper to get it working then to buy a new one.
Edited by minorhero
Remember that spoils  may already be spoiled.
Unless it's dirt cheap, and you have the time, I'd personally leave something without a motor or damaged motor alone.   Who knows what other issues its going to have once the motor is fixed.
Here's the motor info from my 20" planer.
Here's the motor itself.
You are awesome! I know that probably entailed some serious dexterity, or you took a panel off, so thank you.
Anybody have a guess for the motor frame? That is probably the last piece of info I need to find a replacement motor. Also, as I suspected, the motor is Taiwanese. Maybe not a bad thing, but that is the one component I like to buy American.
Yes, I removed an access panel at the base of the planer.  BTW I've had great success with the planer.  Also be prepared to connect up a dust collector and one which you don't mine emptying often, very often!
