Using Polyurethane
I have made a wooden sign out of laminated plywood that is approximately 1' X 3' and painted it with enamel. It will be mounting 1/4" thick raised letters on it. Since it will be mounted outside, I am looking for some tips on the final finish. I was thinking about polyurethane over the entire sign after I mount the letters but not sure whether to use spray, due to the raised letters, or brush on. Or maybe something else is better that will give me a nice smooth finish. Any ideas?
I would spray General Finishes Exterior 450.   if you email them they can advise on how it will adhere to the enamel, but assuming it is fully cured I think it will be fine.
Depending on where you are going to put the sign I would probably use a spar varnish. If it is under some sort of shelter regular poly would probably be ok, but will need to be re-finished somewhat regularly. As far as application I would definitely spray. Spraying always produces a better finish for me personally. I sand with 400 grit between coats and 800 before the last coat then rub down with the gray synthetic steel wool after the last coat. Probably overkill for an outdoor sign but will produce a nice smooth finish.
Definitely a spar varnish or other outdoor-specific finish, if its used outdoors. Even under a roof, humidity swings will cause wood movement, which spar varnish is formulated to allow.
I used a spar varnish over a sign with some painted parts, and it still looks good after 2 years of full outdoor exposure.
I would finish the letters on all sides before attaching them. Spraying a clear topcoat afterwards is a good idea too.
General has exterior clear waterbourne finishes that won't add the amber tint you get from varnishes. Double check about putting it over oil based enamel.
1 hour ago, AceHoleInOne said:
The raised letters made of wood? Dip the letters in spar to seal, then attach.
-Ace-
Oops....dip letters and let dry, then attach.
