I bought an inexpensive floor drill press from Lowe's and just checked it with an Una-Gauge. The runout on the chuck is .007. The cast iron table is .019 in the front and .009 in the back and .003 left and right. I see no place to make table adjustments. As for the chuck, I took it out, cleaned it and reseated it for about the same results. Any ideas or is it just no good?
Meh, you're working with wood, not machining metal.  I certainly wouldn't worry about the table being flat (you could always build an auxiliary table).  And most of the time a brad point or forstner will self-center anyway so that makes the runout fairly moot.  For all but the most critical operations I say you'll never know the difference.  A drill press is one of the less important machines to be dead nuts dialed in perfect for woodworking.  Even my Powermatic leaves some precision to be desired.  I wouldn't worry about it...upgrade one day when you can't think of anything else to spend money on.
I can't think of anything I use the drill press for that a little runout matters. If you can think of an application it would try it and see if any problems.  Sometimes we worry too much about the numbers instead of real-world results.
And just to be contrary (not with malicious intent, just to show another side to the story) I turn to the drill press when I do need accuracy.  I can drill a straight enough hole with an egg-beater or a cordless.  when I want real accuracy and repeatability is when I step up to the DP.  I do agree though that we are working with wood and not running a machine shop and should view things from that perspective ;-)
If you only use it for wood it is likely not an issue.  The bigger question is what is the runout at full quill travel, it will be multiplied.  In general that level of runout is not unexpected in a cheaper drill press.
  • Who's Online   3 Members, 0 Anonymous, 63 Guests (See full list)
    26,008
    Bob44
    Bob44
