MisterDrow Posted December 9, 2016 Author Report Posted December 9, 2016 No apology needed... it was very apropos to the conversation at hand! Quote
MisterDrow Posted December 12, 2016 Author Report Posted December 12, 2016 Well, after a nasty rabbet tearout incident and then my Sunday getting hijacked, my cabinet doors didn't get finished this weekend, which didn't make me happy. I did, however, manage to get five coats of Arm R Seal on the top, so it's ready to go. Tonight my wife is going to paint the cabinet so the top can be attached. 1 Quote
shaneymack Posted December 12, 2016 Report Posted December 12, 2016 Looks awesome, Cory. What sheen of ARS is that? Have you polished it yet? Quote
MisterDrow Posted December 12, 2016 Author Report Posted December 12, 2016 It's satin... that pic was actually take immediately after the last coat was put on so the final result wasn't as shiny as the pic here shows. If I wanted it to be high-gloss (and had used the gloss sheen ARS), how would I go about polishing it at the end? Quote
shaneymack Posted December 12, 2016 Report Posted December 12, 2016 7 minutes ago, MisterDrow said: It's satin... that pic was actually take immediately after the last coat was put on so the final result wasn't as shiny as the pic here shows. If I wanted it to be high-gloss (and had used the gloss sheen ARS), how would I go about polishing it at the end? What I meant was did you rub out the last coat with a high grit pad (1000-2000 grit) with mineral spirits/mineral oil to knock down off the nibs a make a nice smooth finish. It shouldnt change the sheen if you go lightly by hand. For actually rubbing out and making a glass finish check out Marcs video; Quote
MisterDrow Posted December 12, 2016 Author Report Posted December 12, 2016 What I meant was did you rub out the last coat with a high grit pad (1000-2000 grit) with mineral spirits/mineral oil to knock down off the nibs a make a nice smooth finish. It shouldnt change the sheen if you go lightly by hand. For actually rubbing out and making a glass finish check out Marcs video; No, actually... i hadn't even thought of that but I definitely will. I'm still new to the world of finishing. I've got some 1200 grit at home... I could just wrap that around a sanding sponge and give it a light pass. I'll do that when I get home tonight. How much mineral spirits should I use? I assume too much will damage the finish? Quote
Popular Post shaneymack Posted December 12, 2016 Popular Post Report Posted December 12, 2016 Just now, MisterDrow said: No, actually... i hadn't even thought of that but I definitely will. I'm still new to the world of finishing. I've got some 1200 grit at home... I could just wrap that around a sanding sponge and give it a light pass. I'll do that when I get home tonight. I have only ever done it with a platin pad. Go very light and make sure you use the lube ! Dont be shy to use the lube ! Lube is good ! ...sorry, I dont get to say "lube" very often, just getting it out of my system. I feel better now. 3 Quote
MisterDrow Posted December 12, 2016 Author Report Posted December 12, 2016 39 minutes ago, shaneymack said: I have only ever done it with a platin pad. Go very light and make sure you use the lube ! Dont be shy to use the lube ! Lube is good ! ...sorry, I dont get to say "lube" very often, just getting it out of my system. I feel better now. LOL glad to see I'm not the only one who keeps his inner 12-year-old alive and well! You said mineral spirits or mineral oil... mineral spirits will dissolve the finish, won't it? 1 Quote
shaneymack Posted December 12, 2016 Report Posted December 12, 2016 50% mineral spirits 50% mineral oil. No, it will be fine, you arent dropping it in a vat of minerals spirits to take a bath. It takes very little. 1 Quote
MisterDrow Posted December 12, 2016 Author Report Posted December 12, 2016 4 minutes ago, shaneymack said: ...you arent dropping it in a vat of minerals spirits to take a bath... I might be... >_> Quote
JosephThomas Posted December 12, 2016 Report Posted December 12, 2016 LOL glad to see I'm not the only one who keeps his inner 12-year-old alive and well! You said mineral spirits or mineral oil... mineral spirits will dissolve the finish, won't it? Just make sure the finish is cured and you won't have problems. Sent from my Nexus 5 using Tapatalk 1 Quote
wrench3047 Posted December 18, 2016 Report Posted December 18, 2016 I made one a couple years ago for the same reason. I didn't find any plans designed my own version. I didn't consider the weight of a full trash can and recycling bin when I made a single tilting door. When I remake it I will definitely have separate doors. I like yours, mine is no longer in service due to poor hinge design and 2 80lb lab mix meatheads figuring how to open it. 1 Quote
wouldwurker Posted December 26, 2016 Report Posted December 26, 2016 Just make sure the finish is cured and you won't have problems. Sent from my Nexus 5 using Tapatalk Don't sweat it. ARS is pretty much impossible to screw up unless you're leaving huge drips. I've slapped on coats with caution completely thrown to the wind with a dirty rag in a dusty room. Once you got that 4th or 5th coat on there you can sand it and polish it to glass. Also,,.. Cool cabinet. You'll have some stylish garbage! 1 Quote
Popular Post MisterDrow Posted June 15, 2017 Author Popular Post Report Posted June 15, 2017 Oh man... I've been away for so long! Lots to update on lots of stuff. First door frame completed out of poplar with panel inset. I used pocket holes to make it easy... yeah... I don't know if I just got really crappy wood but the poplar wanted to split when I looked at it wrong on putting the screws in. This was the third door frame I made that finally didn't split horribly. Went through two more door frames and even worse splitting when I finally gave up and made the second one out of pine using half-laps on the corners instead. I figured it's getting painted anyways so pine would be adequate. Also, I was sick of working with poplar. Started getting things painted after getting the doors set. Discovered very quickly that while the box itself was square, my face-frames were not. I'm sure I just rushed it at the time but I had to shim the hinges to get the doors to sit properly. Top attached with z-clips, hardware installed, and put into use... FINALLY! It's far from perfect but it functions and looks nice. My next cabinet will be better because I learned a ton on this one. Thanks for following the journey, guys! 3 Quote
gee-dub Posted June 15, 2017 Report Posted June 15, 2017 Looking good. Like children, pets look so innocent when their sleeping. They cannot fool us. we know of their waking activities ;-) Quote
wdwerker Posted June 16, 2017 Report Posted June 16, 2017 That's not a sheltie ! Glad your back to the project . 1 Quote
Mike T Posted June 16, 2017 Report Posted June 16, 2017 Nice job buddy. In my way of thinking (mistakes only you know about) if you're happy with the outcome and effort that's the big thing. I think it not only looks excellent but very functional. 1 Quote
MisterDrow Posted June 16, 2017 Author Report Posted June 16, 2017 That's not a sheltie ! Glad your back to the project . LOL no, that's Wasabi, our Morkie. He likes to climb INTO the garbage can. We've got four dogs... two shelties, a Yorkie and a Morkie. We have a myriad of other animals at our house! 1 Quote
shaneymack Posted June 16, 2017 Report Posted June 16, 2017 Turned out great, Cory! Where have you been?? Sent from my SGH-I337M using Tapatalk Quote
gee-dub Posted June 16, 2017 Report Posted June 16, 2017 Looks terrific. So the bins are tilt-outs? Can you show how that works? The wife caught me looking at this and is getting ideas. 1 Quote
MisterDrow Posted June 16, 2017 Author Report Posted June 16, 2017 Looks terrific. So the bins are tilt-outs? Can you show how that works? The wife caught me looking at this and is getting ideas. Yeah, there's just a hinge at the bottom and I've got a dowel inside to stop the cabinet from opening too far. I think I might swap out the dowel for a small wood block, though, as I'm not convinced it will be enough with my rowdy kids... Quote
MisterDrow Posted June 16, 2017 Author Report Posted June 16, 2017 It was originally going to be against a wall so I left the back open but my wife decided to put it up against the end of the counter instead. I wanted to put a back on it at that point but my wife insisted on leaving it. If she's happy, I'm happy. 1 Quote
MisterDrow Posted June 16, 2017 Author Report Posted June 16, 2017 Turned out great, Cory! Where have you been?? Sent from my SGH-I337M using Tapatalk Busy busy busy. Not a lot of time in the shop but a lot of time getting some life things in order. Been somewhat rough this year on a few fronts but things are opening up again and it feels very nice to be woodworking consistently again. 1 Quote
gee-dub Posted June 16, 2017 Report Posted June 16, 2017 Thanks for the follow up MisterDrow. That is what I thought when I saw the hinge positions but, the extra info helps a lot. Now I have to hide this thread or she'll never let it go ;-) 1 Quote
MisterDrow Posted June 16, 2017 Author Report Posted June 16, 2017 Thanks for the follow up MisterDrow. That is what I thought when I saw the hinge positions but, the extra info helps a lot. Now I have to hide this thread or she'll never let it go ;-) If you look at the original post, I've got a link to the original design I based it off of. It was designed with pocket screws on the cabinet structure but I dadoed everything instead. The face frames and one door are the only things pocket screwed. Quote
