Using Green Cherry for Mantle
First time rookie post here. I need some advice. I cut down a 14 inch diameter cherry from my property to have a buddy saw for a mantle for my new stone fireplace. It will be a 5x8 x 6 ft horizontal top piece for the mantle and two 4x7 x 4ft vertical logs up the sides to box in stone.
I cut the tree a month ago and sawed it today. It will be very green but I don't have a year or five to wait. That is where I need some advice.
Questions
Do I need seal the ends?
Do I need to treat the wood with timbor or boracare if it will be stored inside right after it was sawn?
This will be a rustic looking fireplace so if the wood cracks over time as it dries that is fine. Should I apply some sort of finish before installing or let it dry for a year or two on the mantle first?
I was thinking of using a mortise joint to tie the mantle to the vertical sides. What is my best bet for anchoring the mantle to allow for shrinking as it dries?
Should I try to plane the logs or sand them?
Is it best to show sapwood or resaw the logs smaller?
Any advice would be appreciated for this rookie.
Sent from my SM-G930V using Tapatalk
Sapwood is purely personal preference for a rustic piece like this. You can play it safe with boracare, I would probably skip it unless I saw evidence of bugs. Sealing the ends will help reduce cracking / splitting, but does so by slowing the drying process. As for attachment of the mantel, it won't shrink noticably along the length, so attaching mulitple poibts should be fine. The M&T joints between the top bar abd side columns might open up some, but not enough to ruin it. Just adds more rustic vibe.
I kind of lost you on the deminisions. It will be 5" thick by 8" wide? And it will be made up of the two boards shown in the last pic? They don't look to be 5" thick? And you don't have a year or five to wait, meaning, you want to do it asap?
Thanks the info so far. One beam is about 5 and a half by 8 inches that will be the mantle the other log is just shy of 7x7. I was originally hoping to split it in half to use for the two vertical sides but it just isn't big enough after sawing. So I have to go to camp and cut one more log this weekend from that tree for the other vertical side that my buddy will saw for me.
The reason for the hurry is the wife wants a bunch of other improvements to our family room like redoing the floor so it makes sense to do this fireplace first. And my buddy who cut the logs is also a Mason so he has a few weeks to help me with the stone before the construction season starts.
My 43 years of experience says Don't do it.  You know it will crack a lot, but no one can tell how much it will twist, and it might take three years to find out.
Unfortunately I am almost at a point of no return with this project. I was originally going to use a 150 year old hand hewn beam that was cracked and twisted but the size didn't work. I am ok with it if it cracks. This isn't a piece of furniture it is a rustic fireplace.
Understanding the warnings, risks and likely outcome perhaps the question I should be asking is how best mount the beams to the wall and each other to best control cracking and minimize warping?
This Cherry is very dense so I am not sure if that helps or hurts it from cracking and twisting verses softwood.
One thought I had was to cut two sets of logs now. One set to be used green and one to set aside to dry for a few years. If I mount the mantle and vertical side posts in a way that they can be removed without affecting the stone work, if the green logs warp and Crack terrible, I can remove them, cut the aged set of logs to the correct size and put them back one the fireplace.
I have 50 acres of cherry trees so a few extra logs wouldn't be an issue.
If you are really going for the rustic look drill some counterbored holes for lag bolts and whittle some pegs to drive in and cover the washer and bolt head.
That's exactly what I was thinking about doing. I could always remove the pegs, back out the bolts and replace the mantle down the road if it warps and cracks too bad.
It's a terrible idea but you should do it anyway so you can post before-and-after pictures for our forum so we can show them to the next guy who wants to use green lumber for something.
That stuff you have is sopping wet, not even seasoned enough to burn.  You're asking for a world of disappointment.
Leave off the vertical wood side pieces.
I have a split level house so there is a concrete block wall that intersects about half way up the fireplace. The vertical pieces will have a compound cut to manage the transition from the block wall that sticks out a few inches to the drywall above it. Without using the vertical pieces to box in the stone it would be hard to manage that transition.f29013007785978afd52bc8770b31570.jpg
If I take everyone's advice and somehow convince the wife to put this project off a year, would these logs be sufficiently dry by next spring if I stored them out of the elements?
I talked to the local guy down the road that runs a small kiln he said my best bet was to let them air dry until summer then we can finish them off on his kiln.
Thanks for all the wisdom to steer me in the right direction. I guess the wife will just have to wait for her fireplace.
