Tension? Too aggressive of a curve?  Blade hitting something in the path that it shouldn't?
What size blade? Is it breaking at the weld?  What are you cutting; material, thickness, method?  did this just start happening or has it always done this?
The Emco-star is an interesting machine but, the bandsaw wheels are small and this can cause issues with some blades.  The old three-wheelers were also prone to blade failure for the same reason.  Olsen or better quality blades should be no issue however.
Always breaking at the weld says the blade is not made to bend over the small radius of your wheels. G-Dub hit it in his third paragraph and your statement confirms this. I don't know what the fix it. When the weld material bends tight and then is pulled "flat" again it gets brittle.
  • Who's Online   4 Members, 0 Anonymous, 50 Guests (See full list)
    26,008
    Bob44
    Bob44
