A_Vitale Posted January 25, 2011 Report Share Posted January 25, 2011 I have seen a few that I like but am interested in what you guys have built or found inspiring. I wanna start one soon here as it is time to move into the new shop! Quote Link to comment Share on other sites More sharing options...
mdbuilder Posted January 25, 2011 Report Share Posted January 25, 2011 I did this one a few months ago. It is a design by Christopher Schwarz from Pop Woodworking, might have been in Woodworking magazine and it is also in a couple of his books. Quote Link to comment Share on other sites More sharing options...
Dan S Posted January 25, 2011 Report Share Posted January 25, 2011 I did this one a few months ago. It is a design by Christopher Schwarz from Pop Woodworking, might have been in Woodworking magazine and it is also in a couple of his books. You can get the Sketchup plan here. Quote Link to comment Share on other sites More sharing options...
A_Vitale Posted January 25, 2011 Author Report Share Posted January 25, 2011 Thats it...thats it! That is basically the cabinet that I was refering too and what inspired my post. Every time I look at the roubo bench issue I see the cabinet faintly in the background and have not had a real good look at it. More pics if you could man. I would love to see all the other details like the drawers,link to hardware, etc. Thanks a ton for postin! Quote Link to comment Share on other sites More sharing options...
mdbuilder Posted January 25, 2011 Report Share Posted January 25, 2011 LOL! I have pics . I'll have to look for the hardware stock #'s, it is are all from Lee Valley. Quote Link to comment Share on other sites More sharing options...
A_Vitale Posted January 26, 2011 Author Report Share Posted January 26, 2011 This is greatare the spalted panels just set in say a 1/4 dado?? how about the glass?? Quote Link to comment Share on other sites More sharing options...
mdbuilder Posted January 26, 2011 Report Share Posted January 26, 2011 Yes, the door panels are a 1/2 inch thick with a rabbit on the back side, the 1/4" dimension slots in to a groove in the rails and styles. To mount the glass you assemble the door, route a big rabbit on the back side, add vertical mullions from the back and horizontal from the front, slip the glass in then hold the on place with little strips on the back. Lot's of parts but it is pretty simple really. Quote Link to comment Share on other sites More sharing options...
A_Vitale Posted January 26, 2011 Author Report Share Posted January 26, 2011 So the spalted panel is 1/2? and the door is 3/4 from what I am gathering off the SU plan. Also more info on the back side ...how do the 4'' pieces fasten to the cabinet? 1 Quote Link to comment Share on other sites More sharing options...
Dyami Plotke Posted January 26, 2011 Report Share Posted January 26, 2011 I'm bastardizing my Winter Guild Wall Cabinet Build into a tool cabinet. I don't have any formal plans, but I am posting about it as I go. You can check it out at penultimatewoodshop.com As for inspiration, I review all my inspiraton for the design in this post. The biggest inspiration was article entitled "Tool-Cabinet Design" by Chris Becksvoort from the 2001 edition of Fine Woodworking Tools & Shops (it's a member's only article). Hope this helps, and happy tool cabinet building. Quote Link to comment Share on other sites More sharing options...
mdbuilder Posted January 26, 2011 Report Share Posted January 26, 2011 So the spalted panel is 1/2? and the door is 3/4 from what I am gathering off the SU plan. Also more info on the back side ...how do the 4'' pieces fasten to the cabinet? If by 4" pieces you mean the window mullions they sit in the rabbit and are glued in place. Quote Link to comment Share on other sites More sharing options...
mdbuilder Posted January 26, 2011 Report Share Posted January 26, 2011 Backside of the door Quote Link to comment Share on other sites More sharing options...
A_Vitale Posted January 26, 2011 Author Report Share Posted January 26, 2011 Sorry md what I ment was they are showing four pices behind the slatted board on the very back side (wall side) part of the cabinet! Quote Link to comment Share on other sites More sharing options...
mdbuilder Posted January 26, 2011 Report Share Posted January 26, 2011 OK, there is a board behind the back bords running horizontally which is a french cleat to hang the sucker on the wall. Both the back boards and the french cleat sit in a giant 1" deep rabbit (the rabbit I was cutting on the RAS in one of the pictures above) The cleat attaches with screws in to the top and sides of the cabinet as well as a few short ones into the back boards which are also screwed to the cabinet at the top / bottom andat each shelf intersection. Quote Link to comment Share on other sites More sharing options...
A_Vitale Posted January 27, 2011 Author Report Share Posted January 27, 2011 lol I just pulled it apart on sketch up and realized it was a french cleat... so the other parts to the cabinet side are screwed in to the case? Is some kind of pocket hole used? also what method does the plan call for to dado out for the dividers. I was thinking just routing the stopped dado and squaring it off ?? I really appreciate your help with this man! 1 Quote Link to comment Share on other sites More sharing options...
mdbuilder Posted January 27, 2011 Report Share Posted January 27, 2011 The back and the french cleat are screwed in place. Every other joint except the overhanging top is glued. bottom dovetailed to the sides, top is two rails dovetailed to the sides then the overhanging top is attached to the rails with screws. You can do the dado's however you want, router then square em off or what I did which was to use a radial arm saw. You could do then on a table saw with a stop cut on on side and plunge cut on the other. However you do em some chisel work is needed to square then off. The dividers between the cubbies and the drawers are through dados. Quote Link to comment Share on other sites More sharing options...
mdbuilder Posted January 27, 2011 Report Share Posted January 27, 2011 To be clear, the stop dado's are in the sides for the horizontal pieces. All the vertical dividers are through cuts. They all slide in from the rear once you assemble the case, no need to glue up everything in one massive glueup Quote Link to comment Share on other sites More sharing options...
A_Vitale Posted January 28, 2011 Author Report Share Posted January 28, 2011 Yup I was clear about that, so I guess I am ready to start gluing up then.... Last question...I think! lol Did you just use tongue and groove for the back of the cabinet dadoed in the case? Quote Link to comment Share on other sites More sharing options...
mdbuilder Posted January 28, 2011 Report Share Posted January 28, 2011 The back boards are shiplapped together - rabbits between the boards. The board edge that joins the case is left square and fits in a rabbit not a stopped dado Quote Link to comment Share on other sites More sharing options...
A_Vitale Posted January 28, 2011 Author Report Share Posted January 28, 2011 Cool thanks man, having access to the plan would have been alot easier lol. I wanna build it exactly as the chris did that is why I have so many questions, but I really appreciate your help. As I make progress...I guess once my bench is done I will post pics of the build! If you come across any other useful info or pictures that would be great. Thanks again man! Quote Link to comment Share on other sites More sharing options...
