JohnDi Posted March 11, 2018 Report Share Posted March 11, 2018 Is there a method for cleaning up the "staining" on old iron? most of the tools come out of either vinegar or evaporust with areas of discoloration that doesn't come off even after hitting them with a brass wire wheel on the bench grinder. Link to comment Share on other sites More sharing options...
wtnhighlander Posted March 11, 2018 Report Share Posted March 11, 2018 Wet/dry sandpaper and patience. Link to comment Share on other sites More sharing options...
Chestnut Posted March 12, 2018 Report Share Posted March 12, 2018 I've had luck with scotch brite pads for ares that don't need to be flat. That or steel wool. Link to comment Share on other sites More sharing options...
SawDustB Posted March 12, 2018 Report Share Posted March 12, 2018 Depending on how bad it is, I've had luck with using autosol polish and a buffing attachment on the drill press. It helps take done of the black off without making it look new. Link to comment Share on other sites More sharing options...
