elpansonloco Posted July 12, 2018 Report Posted July 12, 2018 I have a vintage cast iron Parks like 12" planer, couple hundred lbs in weight with a dual voltage motor. Problem is the plug is a commercial 3 straight blade with a 115/240v plug. Is there a way to tell if its wired for 110v or 220v without opening the motor? Like I said, its heavy and currently stored in a spot in my garage where it would be a pita to move. ps, before I acquired this planer I bought a Ridgid 4331 that I can still return but heres my dilemma, I can move around the Ridgid and the cast iron planer would probably have to sit outside since I dont have the room in the garage. I never used a heavy cast iron planer and just wondering if in the long run it will be worth having for occasional planing. It was given to me free. Quote
drzaius Posted July 12, 2018 Report Posted July 12, 2018 The surest & safest way is to remove the cover from the motor junction box to check if it's wired for 120V or 240V. The motor nameplate should have a wiring diagram on it showing you which is which. FYI, the voltage listed on the nameplate will probably be 115V or 230V even though those voltages aren't available. It's just a convention. Whatever you do, don't trust the plug on the cord. Previous owner(s) could have put anything on there. A 3 blade plug can only be rated at 125V or 250V, not both. For both, there would have to be a ground plus 3 blades Quote
elpansonloco Posted July 12, 2018 Author Report Posted July 12, 2018 Thanks. I'll crack it open to be sure but honestly wont know a 110v vs. 220v wiring system in the motor, guess I'll take a pic sooner or later. Would you know what model this planer is? There is no data plate except for the General Electric 115v/230v motor plate. Quote
wdwerker Posted July 13, 2018 Report Posted July 13, 2018 Join "vintage machinery " and I bet someone there can help. Quote
