Hi Folks:
I'm restoring an old Craftsman 113 table saw (yes ... I know I can't turn a pig into a racehorse ... but I can make a fast pig!!)
I'm replacing the 1.5HP motor with a 3HP motor, and adding machined steel pulleys and a link belt.  I've also made PALS-style adjuster brackets for the trunions, and am making an adjustment tool with a dial indicator.
My question is ... what speed should I run the blade?  The motor is 240 volts, 15 amps, and spins at 3450 RPM.  I have several options for pulley sizes, and can pretty much spin the blade at any speed I choose.
What speed do you recommend?
Thanks!
PS:  This is my first post on this forum ... is there a way to "subscribe" to this topic and receive an email notification every time it gets a response?
My take would be that the typical contractor type 10" table saw or the Hybrid type 10" shop saw (both with 1.5HP to 2HP motors) would have an arbor speed of 3450 to around 4000.  A 3HP and larger cabinet saw would be in the 4000 to 4300 range.
I would think that the old 1.5HP motor was 3450 rpm.  So going to a 3 HP motor, I would stay with the same size pulleys that the old motor had for your larger motor.  If it was me, and I was going to upgrade the pulleys, I'd get dual V-Belt pulleys and a matched set of belts instead of the link belt.
QHC
QHC
Yeah ... I understand what you mean ... I've gone back and forth between the link belt, dual Vs, or a serpentine belt.
Basically, I just want a transmission system that runs smoothly without vibrations and without any slipping.
Something that might be a concern is the increased motor weight. With the motor hanging out back & their lighter trunnions, many contractor saws will flex out of alignment when at 45 degrees. No idea how it will affect your saw, but just something to think about.
I had a 1.5 HP contractor saw & had problems with belt slippage & vibration. A link belt cleared that right up, but I don't know if it would handle 3 HP. Serpentine belts require lots of tension, which I don't think would be provided just by motor weight.
I know my post is full of what-ifs & maybes, but I just wanted to throw these things out there to think about.
 Irregardless of the blade speed plan on replacing the arbor bearings and get a decent fence. The original fences were pretty bad. You realize your trying to put a V8 into a Pinto don't you. Of course a lot of things really depend on how old and how worn the saw was to begin with.  Even new bearings aren't going to help a worn arbor.  Have you checked the top for flatness ?
I'm pretty sure you can turn on notifications and in the upper right corner is a box to click &  [ follow ] this topic. If you have the time and machine shop tools & skills you can rebuild almost anything.  Please post pictures of the saw and your results.
Oh and Welcome to the Forum ! Lots of knowledge & opinions from woodworkers of all levels scattered all around the globe.
Some good points being made.  I totally agree with the Serpentine belt requiring more tension than the weight of the motor would provide.  My experience with link belts is that they are way over rated. If you have vibration, it's because something is out of wack (that's a pretty technical term) the pulleys or the bearings, or the v-belt itself had developed an issue, but v-belts should run smooth if the bearings, pulleys and alignment are all good.
Having said that, I have an old Craftsman saw from the 60's.  I think it's a 100 series, but it doesn't say.  I put a 3 HP Marathon compressor motor on it from the Surplus Center with dual v-belt pulleys and a matched set of Goodyear v-belts. It had 2 cast iron tabletop extensions and one stamped steel Craftsman extension, plus a wood one I made (1 on the left and 4 on the right of the blade). I put a 6' Jet fence on it.  That saw ran fantastic.  My only gripe with it was the blade raising/lowering mechanism didn't have a lock, so the blade wouldn't hold it's position.
Mine originally (at least when I bought it 2nd hand) had a 1 1/2 HP motor on.  I don't think the increased weight of the 3 HP motor was an issue.  Things that were built back then were way over built as compared to modern machinery.  I used it that way for a few years and it was still going strong when I replaced it with a Jet sliding table saw.  The trunnions can be hard to adjust, but well worth the effort to be sure the blade is not already parallel to the miter slots.
Definitely trash the fence because the trash is exactly where it belongs!  Post some pics.  I think you'll have a very usable saw once completed.
QHC
  • Who's Online   3 Members, 0 Anonymous, 50 Guests (See full list)
    26,008
    Bob44
    Bob44
