PeteMurphy Posted October 11, 2019 Report Posted October 11, 2019 Hi! I am a relatively new turner - I took a beginners class and then found a small Jet lathe on craigslist. It came with some carbide replacement head tools, so I decided to start with those. I have been trying a couple of small bowls and am seeing a whole lot of grain tearing. I never experienced this in my class (which was taught on the same lathe), so I wonder if it is the carbide tools? The lathe is completely level and weighted down with the stand plus a couple large bags of sand. Should I switch to traditional tools? Any advice would be super appreciated. Quote
pkinneb Posted October 11, 2019 Report Posted October 11, 2019 Welcome Pete! I have some turning experience but we have a couple folks that are awesome turners so hopefully they will chime in. I will say I personally can get better shavings off traditional tools but before going that route have you tried rotating the cutting edge on the carbide tool? I also use a leather a strop sometimes on my Easywood carbide tools Quote
Bankstick Posted October 11, 2019 Report Posted October 11, 2019 Welcome to the wonderful world of woodturning. Also, look at www.woodturner.org for a specific website for woodturning. Quote
Popular Post Mark J Posted October 11, 2019 Popular Post Report Posted October 11, 2019 Hey, @PeteMurphy , welcome to the Hotel California of woodworking. I'm primarily a woodturner, and I primarily use carbide scraping tools. Assuming that your class taught you to use traditional tools and this is your first foray with carbide then you and pkinneb are correct, the most likely factor in the increased tear out you are seeing post class is the carbide scraping tools. Increased tear out is the trade off you make for ease of use, and replaceable cutting edges, as well as the capabilities of carbide scrapers which are different than those of bowl gouges. I use carbide tools primarily for the latter factor, but I expect and accept that I will have to do lot of sanding. There are some steps you can take to reduce tear out with these tools. If the cutters came with the tools and you don't know how much use they have seen then consider replacing them. If these are Easy Wood tools (or will fit their inserts) consider spending a few bucks more for Easy Woods negative rake inserts. These will significantly reduce, but not eliminate, tear out. If you go the regular cutter route check out AZ Carbide for good pricing. When you do get new cutters you'll need to mark the first position and decide on a rotation schedule. Use a Sharpie and put a line on both the top surface and the surface that is obscured by the tool's mounting bed. The latter will still be there if the former gets rubbed off. Since I use about 180* of the round cutter's surface I stick to 4 rotations (N S E W), then discard. You'll have to figure out your own schedule and frequency, but remember using dull tools is a dull idea. Keep a light touch on the last 1/8 or so of material you're removing. That's really key. Also, if you did not know, tool position is zero pitch and zero roll with the cutter altitude set at the equator. 2 1 Quote
pkinneb Posted October 11, 2019 Report Posted October 11, 2019 Great info Mark! Thanks for sharing Quote
PeteMurphy Posted October 11, 2019 Author Report Posted October 11, 2019 Thank you Mark! I will give this a shot and let you know how it works out.. Pete Quote
Mark J Posted October 11, 2019 Report Posted October 11, 2019 By the way, I meant to ask what part of planet Earth are you writing from? Quote
PeteMurphy Posted October 11, 2019 Author Report Posted October 11, 2019 From NY - lathe is in my very tiny basement in Brooklyn. Quote
Bankstick Posted October 12, 2019 Report Posted October 12, 2019 Pete, graduated from Grover Cleveland HS, Ridgewood, NY, USA. Quote
jbiller79 Posted October 22, 2019 Report Posted October 22, 2019 I am a turner that started out on carbide and then switched to traditional. My advice is to make a piece with carbide. That way you get the satisfaction of a completed job. In the meantime buy a bowl gouge from Thompson wood tools. Invest in a good grinder and Wolverine sharpening jig. Learn to sharpen because if you don’t, traditional tools will only make you mad. Once I got traditional tools down, I have never picked up the carbide tools since. You get a much better finish from a sharp tool. Quote
