Triton 450W Oscillating Spindle & Belt Sander or Triton 450W Oscillating Spindle Sander
Looking to buy a spindle sander and I'm not sure what way to jump.
I think the added benefit of the belt sander combo could be handy but looking at the machine it seems that the belt sander part does not have a lot of surface area to work with.
Spindle sander option only comes with a cast iron top and the combo unit only comes with plastic.
Wondering if the spindle sander only and the addition of a seperate disc sander might be a better way to go ?
Anyone with experience with either / or ?
Recommendations and opinions welcome
Thanks
I have a Ridgid spindle / belt sander of the same format as that Triton. It is a very useful machine for small-ish work and small workspace, but you are correct. The platten is not very large, and the belt is short enough that it clogs with spoil quickly. A belt 'eraser' is an essential accessory. I rarely use the spindles, as they are difficult to keep tight on the rubber core, and clog up even more rapidly than the belt. For a hobby volume of work, its a pretty good arrangement, but maybe not for larger tasks.
Thanks wtn
that's interesting about the spindles not staying tight as the spindle part is the main reason I wanted one.
I only do small hobby work, kids toys, bandsaw boxes etc and the spindle sanding would be helpful, I just wasn't sure about needing the belt option.
I will have to have a rethink about the whole deal
The combo (I have the rigid model as well) is handy if you are extremely tight on space, but if you think you'll ever upgrade to a dedicated edge or disc sander, I think you'll be better off with the dedicated spindle sander.
The deck on the combo unit is also prone to deflection and bowing in my experience.
I have the Rigid combo and like the belt feature.  I've not used the spindles, yet.  I don't consider it to be a precision machine  but it is useful (I do smaller objects, too).  The built in dust collection is not great, but I don't know that any other sander does that well, either.
I also have the Ridgid Combo unit. I haven’t had any trouble with the spindle coming loose, but agree with everything else. I use the belt 75% of the time. I will say that the belt sander has drawn more blood than everything else in the shop combined. It’s probably bad form, but it’s very prone to launching small pieces across the shop at about mach 2.
I plan on getting a dedicated disc sander so I will go with the spindle only option
Thanks
Thanks Mark
Sounds nasty
On 1/23/2022 at 3:15 AM, wtnhighlander said:
To clarify my statement, I do a lot of my shop work in the cooler winter months, when the rubber spindle 'sleeve spacer'(?) isn't as flexible. That contributes to slippage quite a lot.
We don't get real cold here in winter, sometimes down to 0c (32f) overnight to 14c (57f) during the day but I'll take that into consideration
thanks
I have a Ridgid dedicated spindle sander and a combo belt/disc sander, mounted on a rotating table, so just the footprint of one machine. On the occasion where my spindle sanding sleeve slips on the rubber roller, I find that wrapping each end of the roller with a round or two of blue tape, helps considerably.
  • 26,012 Total Members
  • JAR Newest Member ·
