So Iam looking at building a federal style sideboard.  It was common back in the day to veneer that front of the horizontal rails between the drawers with veneer of the same species as the rest of the piece with the grain running vertical.  last summer made a mock up of this piece out of poplar and glued poplar veneer to a length of rail.  I pulled ilt out this week and saw that gaps had developed in the veneer.  Let me explain.......The length of the rails is greater than the width of the boards that I had to cut the venner from.  Widest board was about 8" which gives me 8" long pieces of cross grain veneer.  I had to butt the pieces together to cover the length of the rail.  It appears that he 8" long veneer pieces have shrunk and there are now gaps at the joints between pieces.  I think that I used liquid hide glue.  The final peice will be mahogany.  How do I prevent this from happening on the final piece?  The picutre show the gaps in the 1/16" veneer and the banding that was applied later.
Thanks for your help.
Ronn If it were me I would run another test piece using veneer about half that thickness 1/16" ish and Titebond (probably 3 given the mahogany) or a purpose meant veneer glue like Ultra-CAT™ PPR Veneer Glue.
Thanks for the reply.  I have started some test pieces.   All with 1/16" mahogany veneer.  I have to be sure of my method because by the time the veneer is appied the project is ready for assembly and so much work has gone into it that gaps in the veneer would be almost unfixable and catastrophic.
1.  Hold the joints in the veneer pieces together with veneer tape.  Use Liquid hide glue and clamp with cauls.
2.  Hold joints together with veneer tape but also glue the joints from the back side and let cure before applying to rail with hide glue, cauls and clamps.  If this works, it will allow me to glue together enough pieces for my longest rail (27") and in install veneer as one piece.
3.  Iron on method applying 2 coats fo PVA to veneer and rail and letting dry (but not cure) before ironing.  I am thinking that this takes the mositure out the equation.
4.  Same as #3 except use liquid hide glue.
5.  I also need to test if the iron will damge a layer of scotch or packing tape the is use to mask the strip along the rail edge where 1/16" thick banding will be applied.
#1 and # 2 and done - going to wait for glue to cure and check for gaps.
#'s 3, 4 & 5 are in progress.
Incidentally, I talke to Keven Southwick at Woodcraft.  He also suggested doing tests but added that #3 above was his preferred method.  He is usually using 1/42" veneer.
More to come in a few days........
  • Who's Online   3 Members, 0 Anonymous, 70 Guests (See full list)
    26,008
    Bob44
    Bob44
