Popular Post collinb Posted July 15, 2024 Popular Post Report Posted July 15, 2024 I’m putting in some cabinets and bookcases beside the fireplace. We’ve taken out part of the brick and will replace it with cabinets on the bottom and bookcases above. Nothing really complicated. but this time I wanted to do something a little better. Instead of iron on edge banding I decided to go with a hardwood edging. A few of the pieces and this is the technique I’ve come up with. But this time I wanted to do something a little better. Instead of iron on edge banding I decided to go with a hardwood edging. A few of the pieces and this is the technique I’ve come up with. All the videos I looked at spoke of always overlapping both edges and then trimming to flush with the wood, using a block plane. I took an alternative route and made one side only overlap by a hair so that the block plane trimming is minimal thus reducing risk of damage to the plywood veneer. Then on the other side, there is greater overlap to which I apply a heftier plan process and then the final trimming with the block plane. I found the number six plane suitable for doing a piece that’s just under 4 foot long. It gives me some geometry for smoothness, but avoids the bulk of using a seven or eight plane. Then, after a final trimming to width on the table saw then I can apply the stain. The process seems to be coming along nicely. The first couple of boards had some flaws, but I will hide them by putting them against the outside wall, where the flaws will never be seen. ;-) The process is taking me much longer than I would like, but that’s a price of having something nicer. 6 Quote
wtnhighlander Posted July 16, 2024 Report Posted July 16, 2024 That's quite a smooth edge! I'm afraid my hand planing would have gouged the veneer, for sure. 1 Quote
Popular Post collinb Posted July 16, 2024 Author Popular Post Report Posted July 16, 2024 I try to get really close with the block plane and though I didn’t put it in the text, I do a final trim with the router. But only that last little bit. If I hog off too much with the router I end up with a burn on the edge as well. I could also have finished off the last little bit with the sander, but chose the router instead just to keep the squarest possible corner. The first one I did completely by hand came out nice. Then the second and third I did gouge the veneer a bit so I quit doing them entirely by hand. At least the gouging that did occur I can hide against the wall or inside. With the practice I had I could probably do them all by hand alone, but there’s only so many hours in the day. It is a slow process. Yet the appearance of a solid piece of wood gives so much more depth visually than does a simple iron on veneer edge banding that I think it’s worth it in the long run. 4 Quote
Popular Post collinb Posted July 18, 2024 Author Popular Post Report Posted July 18, 2024 To avoid gouging, keep the edge of the plane away from the plywood. That means, trim the edge with the edge of the blade rather than the center of the blade. 6 Quote
Popular Post collinb Posted July 27, 2024 Author Popular Post Report Posted July 27, 2024 Additional note: One bit of information that was in the online material that I took it for a guide was that the glue needs to be minimal so that you have zero squeeze out. I have found out how critical that was and have a few glue spots that I wish we weren’t there. I’m doing this project for home and wish I had done it before so that my errors would not exist. But alas. There’s a few problems here and there, but still it’s going to look good. 3 Quote
Popular Post h3nry Posted July 28, 2024 Popular Post Report Posted July 28, 2024 I find a card scraper is a good tool for the final step ... go as close as you dare with the plane without cutting into the plywood veneer, then finish with the scraper until a whisper of a shaving comes off the plywood. 3 Quote
