I have a track saw system and love it. No more rough cuts and running to the table saw to finish cut. Several companies have them at much lower prices than Festool. Mine is an EZ Track System from Eurekazone.com. No allowing for offsets, just set it right on your marks and cut. Good precise cuts and totally safe. They even have several handicapped users posting on their forums. Always do your shopping before jumping into a purchase. Hope this helps!
BHough56
How many times do we do an about face?: I am really starting to rethink the table saw in preference for the TS55.
Easy killer. There is now way in hell I would give up my table saw. While the TS55 is a good choice for some types of things, there is still a lot that you cant do with it. Just my opinion.
I make 8' rip cuts on my Unisaur, with no problem (Bies. style fence) $' cuts on 4x8 sheets, I use a shop made zero clearance guide, as previously talked about. A good blade, and just concentrate on holding the saw against the guides fence. Perfect cuts. I like being able to line the edge of the guide, where I want the cut.
On the ts, I use a Vega stock feeder, setup, that has a roller that does a great job of holding stock against the fence.
I've recently purchased a pro-grip - (http://www.ptreeusa.com/edge_clamps.htm http://www.carbatec.com.au/progrip-system_c8360 )
pretty much turns your circular saw into a tracksaw. Can also be used with routers etc. I'm just using it freehand as a fence at the moment, but I will probably get the track and plate attachment so I don't have to worry about wandering off the fence - just lock it in! Much cheaper than a tracksaw! (Yes, probably not as easy etc, but a very good option - if you measure and mark properly it could be your final cut).
I guess the only downside is calculating your offset - but you do that once
I usually get my lumber supplier to make one or two cuts for me.
It makes loading and unloading the stock a lot easier and I don't have to deal with a full sheet in my very small shop.
  • Who's Online   2 Members, 0 Anonymous, 50 Guests (See full list)
