Hello,
I just installed a new zero clerance insert on my table saw. Getting some noise that sounds like the blade is vibrating or out of balance. It is an older saw blade, but seems to still cut good. Should I try a new blade? The insert is solid and stable. The saw is a Delta Uni-saw. Just wondering where to start to look for a fix. Appreciate any suggestions.
Thanks.
I would check to make sure that the blade is not warped or bent in any way. Then after that try a different blade and then assess the arbor. I would say it is probably just the blade.
Is the noise like a whistle? If so, the cause may be the insert itself. I have heard of this before, but have never experienced it. I think it was mentioned in FWW, I'll see if I can dig it up.
Depending on how zero-clearance the zero clearance insert is, the saw blade may actually start to function like an air-raid siren, especially if your dust collector is pulling air through the opening. My B&D hand held planer is like this: Noisy enough by itself, but when you hook it up to a shop vac it screams like a banshee.
I had this exact problem once with my zero clearance and blade. Weird thing is, I checked the blade against the miter slot / fence and nothing was out of wack at all. The cut piece didn't seem to be off, and the blade seemed to be seated against the arbor fine. While their usefulness is debated, I slapped a blade stabilizer on it and the noise went away. However, I recently had to remove the stabilizer to raise the blade high enough to make a fairly big cut, and I had no noise issues. Go figure.
Zero Clearance Inserts often make a little noise at the beginning. I think the blade flexes a little , and occasionally hits the side and removes a little of the insert. Eventually, it removes everything it's likely to hit.
An update, the blade seems to be true but I did find some nicks on some of the carbide teeth. I must have hit an unseen metal object at some point. Think I will purchase a new blade. May have this one sharpened.
IMO Beechwood is dead on. I had the same issue on my new PM2000 saw w/ zero clearance. Within a week (of heavy cutting) it went away. I think initially the tolerances are so tight that it creates some noise. Now I have (I'm guessing here) around the thickness of a sheet of paper clearance on both sides of the guard around the blade. I'm using a 1/8 Forrest blade for what it's worth...
  • Who's Online   2 Members, 0 Anonymous, 50 Guests (See full list)
