Hi,
I'm starting a project where I will be cutting several large tenons. So it seems like a good time to acquire a dado stack and use that on the tenons. I have several other projects in mind where I think a dado stack would be useful. My concern is that I don't have a dado insert for my table saw. I'm not sure I can even get one. At least, I haven't found one available yet.
Should I be concerned about using the dado stack without an insert? Does anyone have experience doing this and what are the drawbacks?
Thanks for any info you can provide.
Don't do it. If you don't have an insert, make one or buy one. The opening left without and insert can cause a pretty extreme safety hazard, even with larger boards. The risk of something falling into the opening and that something shooting back at you at an unbelievable speed is pretty high.
Take some scrap 1/2" plywood and make yourself a zero clearance insert, cut your ply just slightly bigger than your regular insert than double stick tape it to your regular insert, and use a flush cut bit to make an exact copy of your regular insert. For the fine ajustment screws I just use 1 1/4" drywall screws, drill and countersink holes in the locations where the ajustment screw are on the regular insert run the screws into the new insert they will protrude out of the top of the insert mark the screw with a sharpie grind the screw off to the mark. Once you get the new insert in the insert hole and adjusted move the fence over to juust catch the edge of the insert turn the saw on now with a scap piece of wood hold the other edge of the insert down, now raise the dado bade up through the insert , and your in buissness.
post-2926-0-35443300-1349048153_thumb.jp
post-2926-0-77244400-1349048173_thumb.jp
If you get your finger into a dado blade with an insert, you draw back a hand with one less digit. If you get your finger into a dado blade with no insert, you draw back an arm with no hand at all. Your choice though.
What saw do you have?
Pretty relevant question actually. My first tablesaw had a very thin insert (far less than the 1/2" standard on many saws, about 1/8"). It was almost impossible to cut my own insert as a result. Mind you your saw maker should sell a dado insert if that's the case (that's how I got mine).
Cut the tenons flat, in a sled. I never use my inserts with sleds.
Inserts do two things, they support the work closer to the blade than the table allows, and they limit the size of offcut that can fall into the throat. That's all... The sled does both things.
On my ridgid the insert was very thin also I just routed out the bearing areas off the new insert so I was able to use 1/2" ply it worked fine. I now have a Delta Unisaw so 1/2" ply works just fine as is.
  • 3 months later...
Hi Everyone,
Thanks again for the advice and information.  Thought I'd give a quick update.  I finally made a dado insert for my table saw.  Yesterday, I setup the dado stack and tried it out for the first time.  The insert and dado stack seemed to work great.  Can't wait to cut tenons with it.
post-5347-0-19704000-1359386912_thumb.jp
