Flattening water stones
I decided it was finally time to buy a flattening stone for my sharpening equipment. I looked online at the the usual suspects, and decided to buy a DMT DiaSharp stone (220 grit). It was about 50 dollars, and it did a great job flattening all my water stones (1000, 4000, and 8000).
The stone is flat to 0.001 inches, and is 3 inches wide by 8 inches long.
I am thinking maybe I should have sprung for the 300 dollar DiaFlat, but the price was just too high.
Do you guys use DMC flattening stones for your water stones?
I've been using 180 grit paper on glass since I started with waterstones, i've been tempted to go with a flattening stone but don't really see the need to spend that money when I'm getting the desired results with my current method.
The Atoma 400 is just over $100 and is fantastic for water stone flattening. I have a lesser quality iWood 300 and it works very well also. My single sided diamond hone is about $80 shipped (from Japan). Both are superior to and less costly than the other...
I use the same DMT Diasharp as you for flattening my stones. I'm new to woodworking and sharpening but I think that the DMT does a great job for the price. Maybe the DMT flattening stone would get it a little flatter but for me, I don't see it being worth the extra money.
Speaking of water stones. Im looking at getting a few. I like the ones Marc uses. What are some other brands? That wont break the bank. Are the double sided ones 1000/4000 grit worth the price?
I use King stones as i got a starter pack for about £80. I have a 250 stone and a combination stone ( i forget which grits but its in the 1000s). They do the job, i have never used any other stones so i dont know if they are softer or how they compare.
I am using this: http://www.leevalley...3072,67174&ap=1
I dont sharpen often so its been ok so far.
I had one of these, and returned it after realizing that it would need truing itself after moderate usage. The DMT stone is only 20 dollars more, and it will last much longer (and never need flattening).
Depends on what you are sharpening. If you are sharpening plane blades, many combo stones are not wide enough to sharpen a plane blade comfortably. I bought a 1000/4000 combo stone years ago for sharpening chisels, and it is pretty much useless for plane irons as it is only about 2" wide.
I have been using Imanishi stones, which I really like. You can get them at Lee Valley. I use 1000x, 4000x, and 8000x. I also have a 220x (norton) for any heavy knicks (usually only in my "rat" chisel, used for scraping glue).
I recently purchased norton 1000/8000 and have good results for plane irons and bench chisels. I use DMT Duosharp (coarse/ extra coarse) for flattening and establishing an edge on ragged tools. I really like this set up.
