pghmyn Posted February 2, 2013 Report Posted February 2, 2013 So, weirdly enough, I was pondering today about blades for planes, chisels, etc. I have never sharpened a blade for my tools before, mainly because I have never owned a plane - and I just bought my first set of chisels recently. So, the question goes, how long does a blade last? How many times and how ofter do you have to sharpen a blade before it is too small? Is it even possible? Just something random I was thinking today Quote
RJsumthn Posted February 2, 2013 Report Posted February 2, 2013 The blade will last a long time. Under normal use a blade or chisel should last a lifetime as long as they are maintained. Quote
duckkisser Posted February 2, 2013 Report Posted February 2, 2013 as for sharpening as you use them more and more you will realize when its dull and when to sharpen. there no rule how often to sharpen you just know because it harder to work with the blade. so when you have to force the edge on harder then normal think about touching it up. Quote
tdale51@yahoo.com Posted February 2, 2013 Report Posted February 2, 2013 Just to give you an idea how long a plane blade lasts; I have a Stanley #5 jack plane that is almost 100 years old, still has the original blade in it. That being said, it is time for a new blade. Over the years it's been worn down to where the edge is too close to the cap iron screw for my liking. Like Duck said, there's no hard and fast rule for when to sharpen your tools. There are some good indicators though...when it takes more effort then normal to cut with the tool it needs to be sharpened, If it tears or crushes the wood fibers it needs to be sharpened. If you take your chisel or plane iron and place it on your thumbnail and it catches your nail under it's own weight instead of sliding off, it's probably sharp enough. You could also try shaving off some arm hair but eventually you end up with bald arms. Quote
duckkisser Posted February 2, 2013 Report Posted February 2, 2013 here is a sugestion talk to hard core wood turners theyhave to sharpen there tools and regrind like every hour. i have not been doing it long enough to tell you how long it took to buy a new tool. Quote
