Mzdadoc Posted December 19, 2014 Report Share Posted December 19, 2014 Not sure the term for it (quill) The shaft that comes down that houses the chuck moves maybe 1/8th" It doesn't stay true. I've had the press less than a year and bought it on Amazon. Should I see about returning it or is there an adjustment? Quote Link to comment Share on other sites More sharing options...
Tpt life Posted December 19, 2014 Report Share Posted December 19, 2014 Many are friction fit. Try a wood block and mallet tap to reseat it. Quote Link to comment Share on other sites More sharing options...
wdwerker Posted December 19, 2014 Report Share Posted December 19, 2014 Good Question ! Haven't had to use Jet service or parts much so I wish you luck ! Quote Link to comment Share on other sites More sharing options...
Mzdadoc Posted December 19, 2014 Author Report Share Posted December 19, 2014 C That's not the part moving. It's the keyed shaft that houses it. Quote Link to comment Share on other sites More sharing options...
skiback46 Posted December 19, 2014 Report Share Posted December 19, 2014 I bought one of those a few years ago. I noticed (new/unused) it had about an 1/8" movement when fully extended, and a little over a 1/32 when the quill was fully in the housing. I exchanged it for a new one, and within a month the replacement had the same problem. After that I returned it for a refund. On the old ones you could tighten the quill housing, or replace the bearings....but I didn't want to do that on a brand new tool. Hopefully its still within warranty. Quote Link to comment Share on other sites More sharing options...
dwacker Posted December 19, 2014 Report Share Posted December 19, 2014 Which one do you have? 1/8" is a bunch look for a loose set screw. Quote Link to comment Share on other sites More sharing options...
Dan S Posted December 20, 2014 Report Share Posted December 20, 2014 Which one do you have? 1/8" is a bunch look for a loose set screw.I agree with this, an 1/8" sounds like something is broke, missing, or in really bad need of adjustment. Quote Link to comment Share on other sites More sharing options...
Mzdadoc Posted December 20, 2014 Author Report Share Posted December 20, 2014 Here's the model I have. Quote Link to comment Share on other sites More sharing options...
Mzdadoc Posted December 22, 2014 Author Report Share Posted December 22, 2014 There is a set screw with a lock but that came loose. Whew! I really like this drill press. Quote Link to comment Share on other sites More sharing options...
