Spencer_J Posted April 9, 2013 Report Posted April 9, 2013 One space two tools. Im looking at both of these tools for medium production of small curved goods, jigs,templates, and the occasional skunk or reindeer for the yard. Ive had equal experience on both. Both tools are readily available via craigslist in the heavier duty format. Do you guys have any input? Im staying away from the imports, making sure i choose wisely so that i dont have a table top dust collector. I also like making keychains Quote
G S Haydon Posted April 9, 2013 Report Posted April 9, 2013 Hi Spencer I will interested to hear the opinions of others on this. My gut tells me a bandsaw will be more be more useful over a wider range of applications. 1 Quote
Levi Rathje Posted April 9, 2013 Report Posted April 9, 2013 Spencer, unless you plan on making small figures or working on pieces 2" square I would go with the small bandsaw. Get a couple of blades like a 1/4" & 1/8" and you can cut pretty darn small curves. You will also be able to use the bandsaw for larger pieces and thicker material. I have a 9" bandsaw and am able to cut up to 3 1/2" thick. Dust collection is handled by a shop vac and dust deputy. I bought thus little bandsaw 3 yrs ago and have never regretted it. If I had a scroll saw I don't think I would use it more than once a year. Quote
dwacker Posted April 9, 2013 Report Posted April 9, 2013 Two different tools two different purposes. Yard art , jigs and templates I'd saw bandsaw. Quote
Spencer_J Posted April 9, 2013 Author Report Posted April 9, 2013 Thanks for the input! Don, i'm interested in the differences between the tools if you could elaborate. Thanks for your time Quote
dwacker Posted April 9, 2013 Report Posted April 9, 2013 A bandsaw has a continuous circular band. A scroll saw uses a double ended blade that just moves up and down. The key is that the scroll saw has an up stroke so it is not a constant cut so you have to go slow. A scroll saw can start in the center of a board with a pilot hole a band saw needs an exit kerf. Scroll saws can use tiny blades some the size of tiny wire that will make very tight corners. Any band saw would be considered HD compared to a scroll saw that is made for delicate work. Cutting your pink flamingo's for the front yard is going to give the scroll saw a work out that its really not made for. But if you want to make little intricate veneers and things like that the scroll saw is the way to go. I would suggest you look for a used Hegner on craigslist if you plan on going the scroll saw route. Quote
krtwood Posted April 9, 2013 Report Posted April 9, 2013 Third option: A good jig saw A decent scroll saw is the last scroll saw you're going to buy. A small band saw inevitably leads to a larger band saw. If you go the band saw route just skip the small one and don't get anything smaller than a 14". Quote
Spencer_J Posted October 19, 2013 Author Report Posted October 19, 2013 Quick update here... I went to check out a delta 14" bandsaw from a craigslist ad back in april. The guy wanted $400 for it and the PO was deceased. It looked like it came from a school with the paint etc. so i passed. He did however have a Delta 40-440 sitting in the corner. I had never seen one in person and it was very substantial. For $150 i got the saw, rolling stand plus an extra table, 3 drive shafts assemblies and another bucket of misc. parts. After i got home i began to get buyer's remorse. It was suuuper loud and clangy. Nothing was straight and the machine was sopping wet with oil. Since it was a birthday present, i kept my mouth shut an continued to look for a solution. 6 months later i have a gold mine. Turns out the PO scrapped parts from several other saws to make this one a hot rod. From the variable speed attachment to the matching rockwell flare leg stand with wheels that retract, to the $500 driveshaft upgrade, and 6 backup chucks, its incredible. A guy named bob vaughn on owwm has documented a lot of his work on these specific machines. The castings are very similar to the powermatic 95 and many rockwell, homecraft scroll saws. I'm not much of a scroll saw guy but if i can cut 7/8 hard maple on a 1/8" radius, it works for me. Through my journey, i also realized how rare and precious parts are for these machines and all old machines for that matter. Quote
woodieboy Posted October 24, 2013 Report Posted October 24, 2013 Not so much luck but sounds like things are working for you now. Can you post a picture? Quote
Spencer_J Posted October 24, 2013 Author Report Posted October 24, 2013 This was taken right when i got it but looks about the same now 1 Quote
