Help me fix a screw-up in sawing out my Moxon Vise
My rip-sawing was off-line when I was roughing out the front board for my benchcrafted moxon vise. I also didn't give myself enough wiggle room. Long and the short of it is there is a off-line part of a kerf that goes about 1/16th" or 1/8th" down in the middle of the top of board. I came back from the other side of the board and was online with that attempt.
So how do i fix this?
I've thought of:
a) leaving well enough alone
B) cutting a chamfer in the front (like some folks do to help with half blind dovetails) - this would get rid of most of it.
c) take the front board (and the back board*) down just enough shorter eliminate the errant kerf
d) start over and cut an new front board
e) something brilliant that I as a new woodworker haven't thought of
* Benchcrafted suggests the front board being an 1/8th" deeper than the back.
TIA,
Tony
Over at SMC, I had a suggestion to laminate a piece on top which sounded good if necessary.  I'm leaning towards option ©.
If it were mine, I would likely plane down and laminate a piece of contrasting wood. Make it look like its on purpose :)
Or start a new board...
Other than that, the other options you have pointed out sound good. :)
==> down in the middle of the top of board
I built my Moxon about two years ago, and didn't remember that any board had to be an exact size...  I didn't build mine to Benchcrafted's exact spec -- I built it with what I had available... Why not simply plane the board down and adjust the other boards accordingly, if applicable?
BTW -- The full 24" Benchcrafted Moxon is a bit of a beast to store, manage, etc... After all, how many times do you build a blanket chest and need to dovetail the sides?  I built mine about 50% shorter to hold 12" boards for dovetailing...  Quite a bit lighter, more manageable and easier to store...
Just a suggestion..  What about cutting an equal amount of wood from both sides and laminating contrasting wood to each side?
I didn't figure deviating on size a little bit from BC's plans would be a problem.  Laminating would be ok but the only contrasting stock I have is some 8/4 cherry that I haven't touched -- wouldn't look forward to ripping out the strip.
I know what you mean about the size of the vise; it's going to be a beast.  I'm really thinking of doing a smaller one with wooden screws eventually.
==> I didn't figure deviating on size a little bit from BC's plans would be a problem
I wouldn't make more of it than necessary... it's just a vice. I wouldn't bother laminating a strip of contrasting wood just to make-up a non-critical dimension...
But I want it to look pretty lol.  Sad to say for as long as I've been 'starting woodworking' this will be the first project I've brought all the way to completion.
Ok, the piece that was supposed to be 5 1/2" in height come out at 5 3/8.  Only 1/8 of a difference.  I'm pretty sure I'm good but wanted to double check before I ripped down the matching back piece that has ample to spare in height.
Apologize for the newbie anxiety ;)
==>   Only 1/8 of a difference.
No problems...  On my BC Moxon, I adjusted both length and width to match stock that was sitting in the cut-off pile...  I think I was about 8" shy in length and about an 1" in width...  It works great...  Covering the opening in suede really helps with holding power...
As you gain experience, you'll find that many projects make 'in-process' dimensional adjustments... It's part of the game...  Sometimes it's due to an unseen defect in the stock, sometime it's due to an 'oops', etc... It happens far more then you might think.  Unless it's something like cabinets, doors, etc that has to fit into a specific opening, most projects can absorb slight changes and just move forward...
  • 26,012 Total Members
  • JAR Newest Member ·
