I am new to this forum and to wood turning.  My question regards cutting logs into blanks.  I want to saw some poplar logs into bowl blanks cutting the length of the log.  Do I need a different chain saw blade to rip cut the logs?  Thanks for any help you can give.  William
All depends on how many you are going to cut and size of the logs. A regular crosscut chain will do fine for smaller logs, up to 12" a 18" as the length of the cut should be about the same. It will not cut as quick as a rip chain but that should not be a problem. On larger logs the rip chain is quicker and is easier to cut straight.
BRuce
I had a few questions about the size of the logs.  I have some poplar logs that go from 12" dia. to some at about 40".  Also some almond logs about 18" to 24" I would like to rip.  The local home depot does not know what a rip chain is so where can I get one?  Thanks William
I had a few questions about the size of the logs. I have some popular logs that go from 12" dia. to some at about 40". Also some almond logs about 18" to 24" I would like to rip. The local home depot does not know what a rip chain is so where can I get one? Thanks William
Rip chain is a name coined by the chainsaw mill crowd. You're looking for a skip tooth in the firewood cutting crowd. They only make these chains for bigger power heads so check your specs. I use Husky 3120xp 's on my chainsaw mill. I get the logosol chain from Baileys.
Rip chain is a name coined by the chainsaw mill crowd. Your looking for a skip tooth in the firewood cutting crowd. They only make these chains for bigger power heads so check your specs. I use Husky 3120xp 's on my chainsaw mill. I get the logosol chain from Baileys.
Would seem I get an education and shown to be a liar all in one sentence....lol
Only thing I run on my Stihl chain saw is a skip tooth chain.
Ripping chain, or any other kind of chain, can be ordered from www.baileysonline.com
  Do you have a saw now, or is this all a new thing for you?  What is the largest sized chunk of wood you want? How long does the rip in the Almond need to be?  I also use a chainsaw mill once in a while.  It's not for the small saws.  I run a Stihl 066 on one end, and an 036 on the other (current equivalent models MS660 and MS360), just because those are the two largest powerheads I have.
A 40" log is doable easiest with a long bar, but can be done with a 24" bar, or even shorter.  It takes a big powerhead to pull a long bar.  Cutting something that big is not something to learn on your own, nor is handling a "man's saw".  Even a 3 to 4 cu.in. saw with a 24" blade is not something to take lightly.
It's easy to get one hung up in a log anyway, with or without a lot of experience, but the bigger and heavier they are, the more severe is a hang-up.  I got the 066 with a 42" bar hung up in a 3 foot Poplar last week.  It was dropped on a little bit of a hill, and I didn't expect the big log to slide down the little slope enough to hang the bar up when I started bucking the log.  Fortunately, we had the tractor with tongs on the loader to lift the end of the log enough to get the saw out.
A skip tooth chain works the same as a low tooth count bandsaw blade.  For big chunks of wood, and limited power, you only want so many teeth cutting at one time.  There are no trees around here that I need a skip tooth chain for, other than ripping chain.  My ported 066 will pull a .404 .063 full count chain through any tree around here for crosscut.
For limited use, I recommend a Stihl MS180 and learn how to sharpen the chain.  You can cut anything with a small saw with a sharp chain.  It just takes longer.  The 180 is the first saw I reach for if we aren't going to be dropping a tree, or cutting much.
Only think I run on my Stihl chain saw is a skip tooth chain.
No you can get rip chains than are not skip tooth but the skip tooth are the easiest to run on small power heads. They eliminate that long grain shredding and steering. :) so much has to do with your power head. I only use mine to dabble in slabs so I'd get some real advice from logosol they know chains.
I do just fine with my standard chains. Even on big pieces i just need to take my time but still works just fine, if i was processing tons (literally tons in weight) of material id probably go for it but until then i see no substantial gains from the extra expense.
You have to keep in mind a true "rip" chain is design to run on a log mill powerhead not free hand. I would not run my mill head free hand it would be un controllable. Skip tooth chains are made for freehand stuff like bowl blanks.
After being around chainsaws a lot as a kid, cutting firewood with my grandpa, I can't hardly bring myself to use one. They scare me!!! So many things can go wrong even if u do everything right.
Several years Iago I found a nice Stihl my neighbors threw out. Cleaned the spark plug and it fired right up. Used it a few times and just was never comfortable with it. Sold it for $150!
I don't know that much about them so I can't help u there, all I can say is be careful. They are very dangerous tools.
As I've never bought a rip chain either, I would probably start my search with a Stihl dealer.
http://www.stihlusa.com/products/chain-saws/
I emailed stihl and asked about ripping chain and their reply stated they no longer sell this type of chain.  I went to www.baileysonline.com   (someone here recomended this site)  They sell the ripping chain but only in 100. 50 25 foot lenghts or you can buy it by the link.  I tried ebay and I found several listings for the chain.
Baileys will put put the chain together for you. You just give them the length needed for your mill. But these are ripping chain for mills not free hand.
This chain is recommended for milling purposes only. It is not designed for standard hand held use. - See more at: http://www.baileysonline.com/Saw-Chain/Drive-Link/Ripping/375-Pitch---050-Gauge/WoodlandPro-30RP-Ripping-Chainsaw-Chain-Per-Drive-Link.axd#sthash.cvlURgDP.dpuf
