David Jordan Posted March 7, 2014 Report Posted March 7, 2014 I am finally looking into upgrading from my shop vac to a dust collection system, however I am running into some questions in regards to the voltage ratings of some systems...right now I have my eye on http://www.grizzly.com/products/2-HP-Dust-Collector-with-Aluminum-Impeller-Polar-Bear-Series/G1029Z2P but in the Electrical it says it is rated 240V Single Phase, while other ones say 240V but they also say 220V, I just had my shop wired up with a 220V outlet, that looks like this, would this work with that dust collector? If not what exactly am I looking for? Quote
pghmyn Posted March 7, 2014 Report Posted March 7, 2014 I'm going to assume the 220v comes from voltage drop over the length of the wire. Should be 240v, but over the length of the wire it may drop to 220v, but still work just fine. Again, assuming here. Quote
dwacker Posted March 7, 2014 Report Posted March 7, 2014 Your fine as long as your set up for the proper amperage. Quote
Tpt life Posted March 7, 2014 Report Posted March 7, 2014 There are ranges that utilities must hit in supply that vary. In some places you find 110/220 and in others 120/240. Your equipment should easily operate within and slightly outside that spectrum. Quote
Tom King Posted March 7, 2014 Report Posted March 7, 2014 220 is old speak. 240 is new speak. Both talking about the same thing. Quote
Trip Posted March 7, 2014 Report Posted March 7, 2014 That's a NEMA 6-20 outlet in your photo. So as long as the DC 20a or lower, you should be fine... One observation, some inspectors interpret DCs as constant load -- it's not quite NEC (the amperage falls below the cut-off), but it's not quite wrong either -- it's one of those gray areas subject to interpretation... So the inspector may require the DC to be on it's own -- which means he'll make you get rid of the second receptacle -- it's picky, but that's your hard-earned tax dollars at work... I've only had one inspector check, and of course, I got busted... I've wired DC as a dedicated line ever since... Quote
Brian Jenkins Posted March 8, 2014 Report Posted March 8, 2014 It can range all the way up to 125/250, but normal now is around 120/240. Its supposed to be within 10% of it which is why it varies someSent from my XT1049 using Tapatalk Quote
