powermatic 15hh planer-DRO and mobile base questions
I just got a pretty good deal on a new Powermatic 15HH planer and have two questions.  The Powermatic version of the digital read out gauge is $150.  Is the powermatic version worth 3X the wixey version.  Are their any substantial benefits other than perhaps making it a bit easier to install?
And on the build in mobile base, I have a rather uneven garage floor.  How well do those wheels work on such a surface.  Will the wheels get stuck in the expansion joint that I will have to roll it over each time I Want to use it.
Thanks in advance.
==>Is the powermatic version worth 3X the wixey version
I've never used the Wixey version... I can tell you that the Jet/PM version are identical and the kit comes with brackets pre-formed and pre-drilled for the Jet/PM mounting hard-points. I'm just not sure about the W.
==>How well do those wheels work on such a surface
Honestly, it's down to our friend with the apple... :) Mass at rest tends to stay at rest and mass in motion tends to stay in motion... I've got built-in casters on various pieces of kit (PM amongst them). I've got an applied epoxy terrazo floor with a marine anti-slip silica layer... The floor has a texture similar to a 24g sanding belt. Stationary tools tend to not move, but once in motion, things like expansion joints (or toes) don't much slow them down.
I have smooth concrete floors but similar results with the wheels and expansion joints. If you get a machine moving the momentum will get you past the joint.
I built my TS's mobile base from 1/4x2x2 angle iron and put 4" castors on it just to be able to roll over something small things on the concrete floor  I've been very satisfied.  My Grizzly cabinet saw can be easily moved but I never have any problem with it moving when I lean on it or cut something. BTW...I never use the locks/hold downs...they're not needed.
post-2896-0-97187900-1403694520_thumb.jp
