12 volt Dewalt drill and driver or portercable 18 volt drill and impact driver
I am wanting to buy a driver and an impact driver set and i am looking at these two sets. I found them on a website that i can pay them out. And these are the sets they have. My question i want to ask is what is the difference between a drill driver and an impact driver. I personaly like Dewalt but which of these would be the better buy,The Dewalt or the Portercable. I use my pocket hole kit very often and just wanted to get a way from the cordless drill. Also I have watched some wood working videos with people useing a driver and when they go to lets say put a screw in a pocket hole instead of stripping the hole out from too much force the driver just clicks out when the screw is at the end. any suggestions and comments would be very helpfull. thanks
I meant i wanted to get a way from the corded drill. my bad.....
I love my little 12 volt Bosch drills and impact driver. I can run up to 3" long screws easily. I usually get the rebuilt ones from CPO Bosch. Most of them were just returned. They send it through quality control, fix anything, replace missing things and offer a full warranty at a lower price than normal. They sell new tools as well.
CPO has Dewalt and all the other brands too.
The main difference between the drill/driver and the impact driver is the chuck. The drill driver has a standard chuck for regular round shank bits and the impact driver has a hex slip lock chuck. Of course the impact has the impact feature that makes driving about any screw or lag a breeze.
 I have the DeWalt 12V set and couldn't be happier. I really like the smaller, lighter size and the quick charge lithium batteries.
I'd go for the DeWalt.  My local school has a few of them, and they've held up well.   Li-ion batteries and small motor innovation have changed the game for cordless tools.  Current 12v can do the work of yesterday's 18v stuff, and it's a lot lighter and easier to hold and carry.  My favorite assembly driver in the shop is a Bosch that's only 10.8v...  It easily out performs my NiCd 14.4 volt tools.
I'm also a fan of comparing remanufactured tool prices against new prices.   I have several remanufactured routers, cordless tools, and a miter saw, and I saved around 25-30% over "new".  It doesn't always make sense, but when the price is right, the same tool quality is there, and it's warrantied.  The first time you use the tool, it's no longer new...  It's nice when someone else takes the price hit! ;)
You should check out the Milwaukee M12 series tools. Great power, light weight, and priced well. I have the M18 brushless drill and impact driver and it's insanely powerful.
I'd go Dewalt as I just did last week. My old 18V has been going 14 years. I just bought the 20V two pack drill, hammer drill driver, two batteries, charger, and bag. If the sale is still at Rockler they give you a free Dewalt router with it. A $129 value They are small, balanced, and strong!
Thanks for all the comments and advice. It is well appreciated. I think i will go with the Dewalt 12v drill driver set. it looks like it will make it so much faster than an corded drill and with the driver it will keep me from accedentally stripping out my pocket holes with to much force. Thanks again
My son uses Dewalt 20V system for automotive work.  He got the hefty XR batteries for longer life.
They also have a USB charger to stick on top in case you need to charge your phone during an extended project.
Our recent window installers used the older 12V Dewalt.  Lighter than the 18V and enough for doing a whole house, with power to spare.
Me ... I'm still corded.
I have the Makita driver set with the 18V Li batteries. They have never failed over the last 5 years of ownership. I have a 16 year old "Default" cordless drill that's been bullet proof even through multiple high level drops.
12v and 18v are intended for different uses:
12v are compact, lightweight, 'handy', light duty, installs, small stuff... I've got the Bosch 12v set -- great. I've got:
Impact driver, drill, reciprocating saw and something else...
18v are 'general duty' DIY level portables... 1/2inch chuck, etc. I've got the Bosch 18v set -- also great. I've got:
3/8" Impact driver, hex impact driver, 1/2" drill, reciprocating saw, and at least two others that I forget. I don’t use any of these in the shop. They are my goto DIY gear.
I also have FT's CXS which is very nice and their 18v drill which I can also recommend.
If you get the 12v, keep the corded tool for the bigger jobs... Even if you get the 18v, you might want a 12v drill/driver for small spaces...
True cord-replacement tools start around 20v+. I've got the Hilti 20v and it's great for larger DIY efforts. I’ve also got the Milwaukee 28v set which is heavy and a bit clunky…
BTW: be careful if you get one of the 18v+ impacts -- even with a clutch, they impart considerable torque... I've twisted-off my share of screw heads with the 18v.
+1 for 18V twisting off screw heads. The torque in an 18V is enough to spin your wrist if you get a hard catch. When I was drilling my studs to run wires, I hit something with a 1" Bosch daredevil spade bit and my drill spun out of my hand and smacked into the wall.
I am experianced with my corded drill doing that kind of thing, but a battery powered drill. WOW thats a pretty powerfull 18V...
