So my saw is only a few months old and in need of repair already.
The red blade lock has a round metal nub that fits in the back washer to lock out and change a blade. Problem is it only sticks down in the washer about 2mm (while there is a 4-5mm deep groove) and hopped out elongating all of the holes. Leads me to these 3 questions.
1- How do you get that back washer off the arbor shaft? Mines now goober'd.
2- Has anyone had this problem and got new parts from PM that were better machined to have a closer tolerance fit?
3- If the answer to 2 is no, does anyone know where I can get an arbor wrench to fit in the slots on the back washer?
First thing’s first, the tolerance on the parts are off... The arbor hub lock pin should fully seat... PM will provide replacements free of charge – any they ‘should’ fit properly... It's a safety thing... They should not even question the repair...
I just downloaded the latest PM2000 manual --- if I map ‘back washer’ to ‘arbor hub’ and ‘goobered’ to ‘needs to be replaced’, then I think we can communicate... :)
Bearing nuts, arbor hubs, etc are usually removed with pin spanners. From the picture in the manual, that’s what you’ve got... The good news – they are DIN sized so you just measure and order – the bad news, they are expensive... While price-seductive, avoid the ‘adjustable’ ones – they are the work of the Evil One... A decent pin spanner (read Swedish, German, etc) is between $30 for a small one (frequently used to replace electric motor bearings) and $120 for a large (car hub, flywheel, etc) – you’re in the middle – suspect a 10-12... Maybe $40... a set is.... well, expensive... :)  And that was years ago...  If you measure to get the size (there are DIN lookup tables), about 50/50 you can borrow one from your local auto repair shop...
PM can tell you how to disassemble the arbor assembly... It’s not hard, just a pain.  Do you have pin spanners, bearing splitters, pullers, etc? If not, get PM to send a service technician...
Good luck.
====>>I just downloaded the latest PM2000 manual --- if I map ‘back washer’ to ‘arbor hub’ and ‘goobered’ to ‘needs to be replaced’, then I think we can communicate...  :)
We are communicating! lol
Thanks Trip, I may have access through work to get some if not all of the above needed to do the swap, with the exception of the spanner wrench. I should have known thats what it was called being a plumber...well, retired plumber is my excuse. We use the cheap version on basket strainers.  ;)
If you push a board against the blade you can loosen the arbor nut without a lock or second wrench. Unplugging the saw would be safer.
 Yeah, did that once and looks semi risky that I can damage a tooth. My new temporary fix is to put some weight on a stick that pushes the lock in farther.
On a somewhat related note, my ptree panel clamp got used for the first time last night only to find out the factory punched the holes  on one of my clamp bars over an inch out of alignment from the rest.
Some 4 letter words were flying around the shop last night.
==>on one of my clamp bars over an inch out of alignment from the rest
how does that happen? Figure the bars would be CNC milled... If I'm thinking of the same setup (the Max-XL?), could the bar just be mounted on the frame and inch high/low?
map 'spanner wrench' to 'pin spanner'... there are also 'hook spanners', 'face pin spanners' and a few others that I forget. I've got a set of pin and face pin spanners, but only a couple of 'hook spanners' - typically used for high-torque drill press and lathe chucks, i've got the former... Your auto or small engine repair guy would have some pin spanners -- auto guys would be a better bet... Although Snap-On sells some really nice pin sockets -- that's what my local guy has --- and those are expensive, but would not work in this case because you don't have access to the entire hub until dissasembled... Let me just take a look -- a set of 4 Snap-On pin spanners is $345 -- the set of 16 is... well, that must be a typo... something about first born male child... never mind... :)
If you have (or can get) the tools you work it at your convenience... Otherwise, they can send a tech and you sit around waiting... It's really not that bad a job - two hrs -- maybe... But it helps to have a second set of hands...
==>how does that happen? Figure the bars would be CNC milled... If I'm thinking of the same setup (the Max-XL?), could the bar just be mounted on the frame and inch high/low?
Yeah, that's the one. You're 2 for 2. It's the front half of one bar that has the issue. I took them off and laid them on a table next to one another. It starts out okay, goes about 8 holes from the top and changes spacing dramatically. I'm thinking they are "punched" out on a machine and the indexing moved or it was built on a Friday after lunch.
Janello how is the shop coming along?
Loving it! I think I can finally call it a shop now. Most everything (major) is in place and I've begun building some shop furniture. I should have a/c and lights in by the end of the month. I have some temp lighting for now. Still have to finish some trim..waiting on a/c so I can trim around it if need be, mostly incidentals. I'll throw some final pics up around the end of June. Can't brag about a construction site any more  :)
  • Who's Online   2 Members, 0 Anonymous, 42 Guests (See full list)
    26,008
    Bob44
    Bob44
